speed sensor still not working
Old Apr 15, 2007 | 11:36 AM
ek4h's Avatar
Default speed sensor still not working
just reaplced it with a new on and its still not working?
before it use to go up and down at random times but not after i swtiched it its not working at all any ideas??
thanks
Old Apr 15, 2007 | 01:11 PM
y7turbo's Avatar
Default Re: speed sensor still not working (ek4h)
maybe the speed sensor is not the problem.
Old Apr 15, 2007 | 01:13 PM
95jeremie's Avatar
https://honda-tech.com/zerothread?id=1934729
Old Apr 15, 2007 | 01:17 PM
speedooo's Avatar
i had the same problem, replaced it, still didnt work. turns out the plug was bad on the harness
Old Apr 15, 2007 | 04:25 PM
byronl's Avatar
try a new cluster
Old Apr 15, 2007 | 05:38 PM
anavrin351's Avatar
Default Re: speed sensor still not working (byronl)
i replaced the sencor in mine and the plug was fine but it didnt work. i put a cluster with a tack in it and now it works. like the other guy said get a new cluster
Old Apr 15, 2007 | 07:49 PM
JDM_EK4_Coupe's Avatar
(banned)
Default Re: speed sensor still not working (anavrin351)
Your plug is probably bad on your harness. I had the same issue and spliced a new plug on and had no issues after that
xjm92x
Mar 21, 2011 09:10 PM
Civicthusiast
Feb 17, 2009 08:30 PM
bboyjimpy
16
Mar 16, 2008 06:28 PM
firo
Jul 26, 2007 04:52 PM
