Is sanding a possible method of removing Dirt stained paint??
Old Apr 14, 2007 | 10:24 PM
User 5426's Avatar
Default Is sanding a possible method of removing Dirt stained paint??
Just got a 1990 cream car for dirt cheap. The problem is that the paint is stained with dirt even after vigorously scrubbing it. These stains only appear on the hood roof and trunk of the car as if the sun baked it in.
The car needs a paint job but I don't think that it is worth it. I just want the car to not look so dirty.
I tried running a brushing the paint with a razor and that seemed to work so I want to know if I can just sand the top layer of dirt away.
Washing with dish soap didn't do the job so I know that car soap wouldn't as they are more mild.
Old Apr 14, 2007 | 11:11 PM
User 5426's Avatar
Default Re: Is sanding a possible method of removing Dirt stained paint?? (EsQueue)
bump
Old Apr 14, 2007 | 11:13 PM
Folgers's Avatar
Bump.
Old Apr 14, 2007 | 11:33 PM
.Thomas's Avatar
Default Re: Is sanding a possible method of removing Dirt stained paint?? (Folgers)
with a hose, go with like a 2200 grit, with soap very lightly
Old Apr 14, 2007 | 11:35 PM
User 5426's Avatar
Default Re: Is sanding a possible method of removing Dirt stained paint?? (TanCar)
thanks
Old Apr 14, 2007 | 11:55 PM
bg-33p's Avatar
Would like to know as well. If you do try this can u please do a write up? Thanks much.
Old Apr 15, 2007 | 12:10 AM
invisible's Avatar
Default Re: Is sanding a possible method of removing Dirt stained paint?? (bg-33p)
clay bar
Old Apr 15, 2007 | 12:20 AM
TSX TEX's Avatar
Default Re: Is sanding a possible method of removing Dirt stained paint?? (cheesee)
Read this .... http://www.autopia-carcare.com/inf-clay.html
Old Apr 15, 2007 | 07:04 AM
SIRIUS's Avatar
Default Re: Is sanding a possible method of removing Dirt stained paint?? (iPnTegRa)
I just clay barred my Buick yesterday and I would try that first if you haven't before sanding. The clay bar works wonders and you will be surprised at what it remove from the paint.
Old Apr 15, 2007 | 07:23 AM
User 5426's Avatar
Default Re: Is sanding a possible method of removing Dirt stained paint?? (SIRIUS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRIUS &raquo;</TD></TR><TR><TD CLASS="quote">I just clay barred my Buick yesterday and I would try that first if you haven't before sanding. The clay bar works wonders and you will be surprised at what it remove from the paint.</TD></TR></TABLE>
Funny, the car I bought was a buick. If the clay removes a small part of the paint then it should work. If it just scrubs off bonded surface dirt as a website says, it will not work. I'll give it a try though.
Old Apr 15, 2007 | 07:31 AM
SIRIUS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EsQueue &raquo;</TD></TR><TR><TD CLASS="quote">
Funny, the car I bought was a buick. If the clay removes a small part of the paint then it should work. If it just scrubs off bonded surface dirt as a website says, it will not work. I'll give it a try though.</TD></TR></TABLE>
What type of Buick? Anyway, yea if you need to remove paint/clearcoat then wetsanding is what you need. I may end up wetsanding myself also but the clay did clean up the surface of contaminents.
Old Apr 15, 2007 | 07:48 AM
User 5426's Avatar
1990 Buick Regal Custom with the 3800 engine.
$550 with a little under 63000 miles. I carfaxed and it showed that the miles are legit.
Old Apr 15, 2007 | 07:57 AM
93whitesol's Avatar
go through a basic detailing procedure before trying something as abrasive as sanding. clay bar, compound, polish etc etc etc
CblP s40
Detailing
13
Dec 13, 2010 01:39 PM
SlAmmmmmed-DB8
Paint and Body
Jul 5, 2009 03:14 PM
SIR EF9
Jul 8, 2008 09:25 PM
blkeg
Jan 26, 2004 11:29 AM
COMplex.
May 4, 2003 01:00 AM
