What aftermarket Intake arm do I need with a BLOX IM?
Old Apr 14, 2007 | 10:08 PM
invisible's Avatar
Default What aftermarket Intake arm do I need with a BLOX IM?
Or skunk2....I know the ITR will work but what others? B16? LS? it's a BLOX IM in a ek.
Modified by cheesee at 1:24 AM 4/15/2007
Old Apr 14, 2007 | 11:47 PM
fmrprojects's Avatar
Default Re: What aftermarket Intake arm do I need with a BLOX IM? (cheesee)
get the itr one cause its 3in diameter and get a velocity stack with a filter on it
Old Apr 15, 2007 | 12:07 AM
nighttrain33's Avatar
Default Re: What aftermarket Intake arm do I need with a BLOX IM? (fmrprojects)
I didn't get to read the original post, but shouldn't it matter based on which motor?
-Shane
Old Apr 15, 2007 | 12:08 AM
invisible's Avatar
Default Re: What aftermarket Intake arm do I need with a BLOX IM? (nighttrain33)
well i have a gsr swap with a blox IM.
Old Apr 15, 2007 | 12:13 AM
I just kept the intake from my d16 when I swapped to a b-, and I'm sure a 3 in. intake arm won't make that much of a difference (depending on mods), but it couldn't hurt.
-Shane
Old Apr 15, 2007 | 12:15 AM
invisible's Avatar
i had the gay d16y7 so the IM was all angled weird. i just need something that'll work.
Old Apr 15, 2007 | 12:21 AM
Is that a downdraft IM?
-Shane
Old Apr 15, 2007 | 12:22 AM
invisible's Avatar
down draft? it's the one where it's pointed like straight up instead of the norm to the side haha.
Old Apr 15, 2007 | 04:48 AM
redhatch8u-up's Avatar
are you planning on using aftermarket intake or do you want to use the airbox? if you are going back to a stock looking setup then use a ctr setup should be able to pick one of those up from hmotorsonline.com if you are using an aftermarket set up then get one for a 99-00 si
Old Apr 15, 2007 | 03:00 PM
invisible's Avatar
Default Re: What aftermarket Intake arm do I need with a BLOX IM? (redhatch8u-up)
oovvutt
91
Nov 26, 2009 09:40 AM
invisible
Apr 14, 2007 10:07 PM
invisible
Mar 15, 2007 09:25 AM
JcAst99
Dec 12, 2006 06:35 PM
