What aftermarket Intake arm do I need with a BLOX IM?
Or skunk2....I know the ITR will work but what others? B16? LS? it's a BLOX IM in a ek.
Modified by cheesee at 1:24 AM 4/15/2007
Re: What aftermarket Intake arm do I need with a BLOX IM? (fmrprojects)
I didn't get to read the original post, but shouldn't it matter based on which motor?
-Shane
-Shane
Re: What aftermarket Intake arm do I need with a BLOX IM? (nighttrain33)
I just kept the intake from my d16 when I swapped to a b-, and I'm sure a 3 in. intake arm won't make that much of a difference (depending on mods), but it couldn't hurt.
-Shane
-Shane
Re: What aftermarket Intake arm do I need with a BLOX IM? (cheesee)
are you planning on using aftermarket intake or do you want to use the airbox? if you are going back to a stock looking setup then use a ctr setup should be able to pick one of those up from hmotorsonline.com if you are using an aftermarket set up then get one for a 99-00 si
oovvutt
91
11-26-2009 09:40 AM
invisible
04-14-2007 10:07 PM
invisible
03-15-2007 09:25 AM
