slow acceleration..
my question is when im pressing the gas pedal the rpm was slowly goin up..
even if its full throttle, still slow.. i tried the timing but still.. cant figure it out.. the car pulling strong like couple of days ago b4 i broke the dizzy n i replace it already.. can anyone help me pls.. thanks..
I have a 93 eg hatch with itr 96 spec.. When its cold it runs strong.. But when its like warm enough it starts lagging... when I press the gas pedal the reaction of the throttle was late..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi »</TD></TR><TR><TD CLASS="quote">yea man, good luck, might as well start replacing everything from your fuel pump, down to your ground wires</TD></TR></TABLE>
rofl +1!
rofl +1!
when the engine is cold it runs strong...therefore when it goes into closed loop the problem starts. try pulling the "back up" fuse for like 15 seconds. (under hood fuse) should reset your ecu. kinda sounds like the ign timing is off
same happens to me now... My reason though is because I took off my IACV and cleaned it out.. and attemting to remove the gasket that looks like an 8, I realized it was dry rotted because when I tried pulling it, pieces of it just started falling off. I now have a small vacuum leak. It's really only affected when the car warms up. When it's cold, the engine pulls NICE but once it's warm.... DAMN IT SUCKS.. Ordered one from HONDA last week.. Week and a half I have to wait for a stupid 2 dollar TINYYYYY gasket/seal. It will be here in 2 days. Did you mess with the intake at all? Timing maybe too... but I don't think it would affect with different temps.
its possible, however a vac leak, is only dominant at lower speeds/rpms/engine loads, so @ wot, it shouldnt be as noticeable. Its gotta be fuel, I had my issue fixed, then it came back (swapped the fuel pump)
now im pretty much clueless since its been 2 years with this problem, it might be something internal.
galdo12
37
Sep 28, 2014 11:32 PM
Seriously what motor and which car?
