will the dealership cover syncos?
Old May 28, 2002 | 05:41 AM
hooptie157's Avatar
Default will the dealership cover syncos?
Well my syncros need to be replaced, my current mods are:
ATS final
Exedy Clutch
Toda flywheel
Mugen Header and twin loop
carsound cat
drop in filter
If they don't notice the final drive do you think they will cover it under warrenty???
Old May 28, 2002 | 06:02 AM
00MRSi's Avatar
Default Re: will the dealership cover syncos? (hooptie157)
I hope they don't notice your aftermarket clutch, flywheel and ATS final drive. If so, I think they're gonna give you a hard time. I hope I'm wrong. Your argument would be the synchros are worn out prematurely, and they should not, regardless of your mods. They are supposed to prove that your "mods" did the damage/wear tear on synchros. I've heard many 1999-2000 Civic Si owners complain of sychro problems. Good luck.
Old May 28, 2002 | 06:05 AM
hooptie157's Avatar
Default Re: will the dealership cover syncos? (00MRSi)
oh synchro is how you spell it (my bad). Anyway my stomich dropped after reading that post. I estimate $2500 worth of repairs if not covered. Damnit!! The exedy clutch LOOKS kinda stock, I hope they don't notice. Anyone else??
[Modified by hooptie157, 7:05 AM 5/28/2002]
Old May 28, 2002 | 06:46 AM
SwiftTypeR's Avatar
New User
i doubt their going to cover it. a good technician can spot your aftermarket stuff easy and void your warranty. btw what did you do to ruin all your synchro's?
Old May 28, 2002 | 06:50 AM
killingtime's Avatar
Default Re: will the dealership cover syncos? (SwiftTypeR)
i dont think it'll be a total warranty void, but getting that ATS final, Exedy Clutch and Toda flywheel past the service writer isnt going to be easy. And if you do, the tech will most likey spot it
Demian
Old May 28, 2002 | 06:55 AM
hooptie157's Avatar
Default Re: will the dealership cover syncos? (killingtime)
well they know about the flywheel, as for the clutch nope and the final is barely noticable (unless you take it out and look at the RPM for the speed). They would have to count the teeth on it. its the least of my concerns.
[Modified by hooptie157, 8:04 AM 5/28/2002]
Old May 28, 2002 | 07:08 AM
Any tech working more than 3 months will notice that the transmission has work.
So under normal circumstances, yes, I would imagine that the dealer would cover the parts and repairs. Under this curcumstance, no, you have a fairly modified transmission and one could reasonably make the argument that the modifications led to the parts failure/issues.
You asked, Im giving my opionion, thats all.
Demian
[Modified by killingtime, 8:09 AM 5/28/2002]
Old May 28, 2002 | 07:09 AM
uNF$@#!'s Avatar
flywheel they may chew you on, clutch i dont think will matter to them.
your final drive however is going to kill you incase they do count.
otherwise, why not try.
Old May 28, 2002 | 07:22 AM
BryanSprinkel's Avatar
I highly doubt they will cover it. Like someone mentioned, a trianed tech will noticed you tranny has been worked on, and will look for the parts. The sad thing is, those parts prob didnt have anything to do with causing the problems in the tranny. Good luck
Old May 28, 2002 | 10:07 AM
hooptie157's Avatar
Default Re: will the dealership cover syncos? (BryanSprinkel)
NOOOOOO!!!!!!!!! I'll kill the guys who installed this stuff wrong
Old May 28, 2002 | 10:17 AM
Reid's Avatar
Global Moderator
What was installed improperly? Your shifting technique is what killed the synchros.
Old May 28, 2002 | 10:19 AM
hooptie157's Avatar
Default Re: will the dealership cover syncos? (Reid)
nope everything started going wrong once the ATS final, clutch, and flywheel was installed. Trust me the car was fine before this. I had to take it back to the people about 5 times for "adjustments." This is bullshit
Old May 28, 2002 | 01:05 PM
slowassR's Avatar
if they dont they will be covering your trani
Old May 28, 2002 | 02:51 PM
smerk's Avatar
New User
It should not cost $2500 to replace synchros unless the mechanic doesn't know wtf he is doing and needs to spend forever to do the job. A brand new ITR tranny doesn't even cost that much. You can usually convince the dealer to cover it IF they think the whole tranny/clutch/flywheel is stock AND this the first time you went to the dealer with this problem. That's a big if so good luck.
Old May 28, 2002 | 03:40 PM
Nighthawk GS-R's Avatar
New User
Default Re: will the dealership cover syncos? (smerk)
hooptie bring it to my dealer and he'll take car of you...........
Old May 28, 2002 | 03:42 PM
EagleR's Avatar
Will I/H/E void any future repairs on tranny stuff?
Old May 28, 2002 | 06:26 PM
SwiftTypeR's Avatar
New User
Default Re: will the dealership cover syncos? (EagleR)
No, unless if your dealer is a ***** about it.
Old May 28, 2002 | 07:11 PM
EagleR's Avatar
Thanks, I didn't think so but i just wanted to check to you sir!
92civicx
Jan 30, 2009 05:31 AM
CALC!_JUST_du_IT!
Dec 7, 2007 09:22 PM
Quickridez_3
Dec 21, 2006 10:07 PM
IloveNewt
Mar 17, 2003 03:44 PM
Rdriven
Nov 15, 2002 12:37 PM
