Can having a D-series Throttle body on my B18B affect my Idle?
I currently have my D16y8 Throttle body on my b18b because the one it came with had a broken TPS sensor. My car is idling a little funny. Can this be my problem? I have already sprayed around for vacuum leaks. Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pythoner »</TD></TR><TR><TD CLASS="quote">yes its smaller, its like snorkeling with a straw insead of a snorkel!</TD></TR></TABLE>
yeah because 2mm is SOOO much smaller
look for a vacuum leak
Well, did you just now put the y8 tb on it and started having this problem or have you had the y8 tb on it for awhile and you started having problems? If you just put it on and had problems then im willing the bet its the y8 tb causing it. Are'nt most honda tps sensors the same? Could'nt you swap them?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">
look for a vacuum leak</TD></TR></TABLE>
I had a CX TB on a D16z6...and I only said it was smaller, not how much smaller!
unknown0001
May 30, 2006 02:29 PM
