Need Help with trouble code P0700 & P0758
Old Apr 14, 2007 | 04:00 PM
240_mph's Avatar
Default Need Help with trouble code P0700 & P0758
Ok the CEL turned on and it was code P0700(Trans Control System Malfunction)0 & P0758(Shift Solenoid B Circuit Electrical). I tested the Shift control solenoid B. I measured the VREF Voltage and it was in spec, I checked if it had short to power abd it didn't, I measured the resistance and it was within spec. I also took it out and checked if it clicked when power was applied but it didn't click and I also took out valve C to check if it did the same thing and it also didn't click, but it didn't throw a code for C, only B. This is a 98' with only 60,000 miles and no racing.
Is it possible that the TCM is faulty?
Any suggestions?
Old Apr 15, 2007 | 05:27 PM
240_mph's Avatar
Any one?
Old Apr 15, 2007 | 05:38 PM
Hawkze_2.3's Avatar
Default Re: (240_mph)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 240_mph &raquo;</TD></TR><TR><TD CLASS="quote">Any one?</TD></TR></TABLE>
I wish I could help, but unless someone has a 5th gen Helms manual it's going to be hard to answer such a detailed question.
Do you have a Helms?
knightnam
Jan 5, 2008 09:05 PM
AccordP13
Dec 26, 2005 05:59 PM
jdmefhondachassis
Jun 23, 2004 04:11 PM
Lei Siew Long
May 19, 2003 03:09 PM
