no spark no fuel
Old Apr 14, 2007 | 02:55 PM
bulldogg9279's Avatar
Default no spark no fuel
im not getting any spark or fuel. and i pulled the plugs. there was no fuel on them. when i turn the key on with the fuel line unhooked. i get no fuel threw there. unless i jump the wires on the main relay. ive swithched out the main relay. with a good one still no start. this all started after i hooked up my vtec sylenoid & pressure switch wires. but i also put the ecu in its little cubby hole. i rechecked everything i did. it all looks good. i decided to pull the dizzy cap. and i noticed it was pretty rusty under there. a under statement. also a crack.. i replaced the dizzy. still nothing.
but when ever i unplug conector D on the ECU the car will run. the main relay will click and the fuel pump will prime as soon as its unpluged. so what in conector D would cause this? it will idle & rev just like theres nothing wrong.
Old Apr 14, 2007 | 09:16 PM
Default Re: no spark no fuel (bulldogg9279)
ttt
Old Apr 14, 2007 | 10:52 PM
RCautoworks's Avatar
Retrace your steps and unhook anything you hooked up, eld is in that connector and will cause some weird things to happen.
Old Apr 15, 2007 | 11:30 AM
Default Re: no spark no fuel (RCautoworks)
i figured it out! when i was pulling the battery tray out. i knocked off the negative battery conector. in the process of putting it back on. some of the wire splinters fell off into the engine harness plug. i did not see this. so i conected the plug. and a splinter made a connection between two terminals. and you ask why the plugs would be down there. cause i did a minor wire tuck. and relocated them under the battery tray. but she runs and the engine light is off.
keslerbuilt
Jan 26, 2014 09:50 AM
boosted423
Aug 4, 2008 08:20 PM
allmotor2.1
Nov 24, 2007 04:52 AM
NFM_Dm
Sep 12, 2005 11:09 AM
advanracing62
Mar 15, 2004 05:57 AM
