4K Idle!!??? WTF
Old Apr 14, 2007 | 01:27 PM
JDMKid71's Avatar
Default 4K Idle!!??? WTF
1997 Civic with B18C1 Y80 trans (engine with H/E/I)
ok so the other week out of no where my car started doing the idle surging thing.. where it was going from like 1k-2k then back to 1k and all over again. Now... it freaking revs up to 4K... WTF? i took my FITV apart and cleaned it, cleaned the IACV, and also took my TB off and cleaned it. No dice. put it all back together and revs up to 4K... now if i unplug the IACV it drops down to like 1k but surges from 1k-1.5k-1k... and also runs REAL rough.? im stumped... i just randomly started unplugging things to see what would happen...
First the Map. - engine run for about 30 seconds real rough like, then dies (all other items are connected)
TPS - nothing with the IACV plugged in but when the IACV is unplugged the car revs back up to 4k?? huh
it kinda seems like there is a HUGE vacuum leak someplace but i have checked all the hoses, nothing!
also when the car is doing the surging from 1k-1.5k-1k i plug the two holes in the TB (for the IACV and FITV) (engine cold) and the car continues to run the same.. like its getting air.. but i dont know where from? any ideas?
HELP ME!! im freaking stumped!
Old Apr 14, 2007 | 02:07 PM
JDMKid71's Avatar
Default Re: 4K Idle!!??? WTF (JDMKid71)
ok just got in from checking some sensors... backprobed at the ECU
Map - 2.8-2.85 V KOEOff 2.3-2.5 KOERuning
TPS - .5V Closed 4.55 WOT (checks good)
ECT - about 2.81V then dropped gradually as the engine warmed up ( i just watned to see it drop a little didnt let it get all the way warmed up.
the only thing that is weird is the MAP sensor is not showing much vacuum in the manifold.. so im thinking there is one f**king huge vacuum leak someplace... but i just cant find it.. any ideas? its not in the IACV or FITV portion, or the break booster...?? maybe its my intake manifold gasket???
Old Apr 14, 2007 | 02:34 PM
Wharbone's Avatar
Check your FITV.
Remove your intake and let the engine get up to operating temp. There is a small hole in the throttle body. Put your finger on the hole. There shouldn't be any suction. If there is, the FITV isn't working correctly.
If that is the case, most likely the plunger in the FITV backed out. You can take it apart and screw it back in.
To check for vacuum leaks, spray hoses with soapy water to locate the leak.
Old Apr 15, 2007 | 06:23 PM
JDMKid71's Avatar
Default Re: (Wharbone)
Wharbone... Re-read the thread.. i have already done that.. i also know how to check it... read the thread next time before you act like you know what the problem is
Another thing that is wrong with your responce is that there are two small holes, on the left side of the inside of the TB.. the FITV is the bottom one... there should be suction from the top one at idle in any temp...
I dont want to spray my hoses with soapy water to find the leak.. this si such a big leak that if i do find it with soapy water, my engine is going to inhale soapy water into th cylinders.. last time i checked water, and soap do not burn....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMKid71 &raquo;</TD></TR><TR><TD CLASS="quote">ok just got .....its not in the IACV or FITV portion.....</TD></TR></TABLE>
this thing revs up to 4000 RPMs when at idle... it is not the FITV... my guess is there is a leak in my intake manifold gasket... any other ideas?
Old Apr 15, 2007 | 06:25 PM
Civic98KH's Avatar
i would first change the intake manifold gasket .. i mean that seems to be the only logical thing right now
Old Apr 15, 2007 | 06:57 PM
ELSUICIDA's Avatar
Default Re: (Civic98KH)
why dont you scan it to see what codes you get. Just an idea
Old Apr 16, 2007 | 03:35 AM
JDMKid71's Avatar
Default Re: (ELSUICIDA)
dont have an OBD-I scanner around at the moment... the only flash code i get is the IACV one because its unplugged so im not actually idling at 4K
I do too belive that it is the intake manifold gasket... i cant think of anything else that would allow it to idle so high. im going to try and totally plug my TB by putting my hand over it to see if the amount of intake air is enough to keep it running with no air through the TB... the other reason i think its the gasket is because i have literally almost NO manifold vacuum... my breaks get REAL hard after about 3 full pumps of the petal, but then return after driving it for about another minute.
im back up at school now and do not have the facilities or tools to fix it up here.. will have to wait another 3 weeks..
Modified by JDMKid71 at 5:57 AM 4/16/2007
Old Apr 16, 2007 | 10:24 AM
JDMKid71's Avatar
Default Re: (JDMKid71)
no body has anything to say or any input huh?
Old Apr 16, 2007 | 10:25 PM
Wharbone's Avatar
You need to re-read what you wrote...
All you said is that you took apart and cleaned your FITV and that you plugged the holes when the engine was cold. You didn't write anything about properly checking the FITV.
I did read the entire thread prior to responding. You were just unclear.
Old Apr 17, 2007 | 11:12 AM
JDMKid71's Avatar
i have properly checked the FITV i guess i just did not make it clear in the post.. however i did say...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMKid71 &raquo;</TD></TR><TR><TD CLASS="quote">.... but i just cant find it.. any ideas? its not in the IACV or FITV portion, or the break booster...??....</TD></TR></TABLE>
and regaurdless with the whole TB plugged (put hand over TB) the engine still runs.. think about that... it should not be running...
Old Apr 17, 2007 | 11:41 AM
scald24's Avatar
Just adding my 2 cents.. After changing my head gasket my car did the same thing. Turned out it was the POS intake manifold gasket. Changed it out and the problem stopped.
Old Apr 17, 2007 | 11:52 AM
1d10t's Avatar
Default Re: (scald24)
maybe the intake manifold is loose. vibration is a kik in the pants. fitv will only make the engine surge unless the iacv is shot anyways. your map shows near atmospheric pressure while idling!
Old Apr 17, 2007 | 11:54 AM
Deep V's Avatar
Check the intake mani gasket... thats what it sounds like IMO.
Old Apr 18, 2007 | 11:16 AM
JDMKid71's Avatar
Default Re: (Deep V)
yep intake manny gasket is what it seems to be accross the board... ill change it here the first of may (when i get home) and ill lte you guys know. thanks guys!
Old Apr 25, 2007 | 05:01 AM
Civic98KH's Avatar
**** i have the same problem now, i wonder if its my intake manifold gasket
Old Apr 25, 2007 | 01:37 PM
JDMKid71's Avatar
well i will be taking mine off this Saturday and will keep you guys up informed... it really has sucked driving around like this... I'm sure I'm going to have to replace my clutch this summer as well because i only can drive and let the clutch out like around 3-4 grand... i really hope i can fix it this weekend
Old Apr 29, 2007 | 12:27 PM
JDMKid71's Avatar
Yup, problem fixed!
It WAS the intake manifold gasket... it was sucked in by the engine at the 2nd cylinder runner. slapped on a new Flepro gasket and tightened everything down and she purrs oh so nicely now!!
the thing that had happened was when i took it off before i never put the bottom two nuts on (because there hard to get to) and i was in a hurry... so anyways i got ALL the nuts on this time and it runs real nice now!! just need to change my oil because of how rich it was running and all the blow by i was having from a shitty running engine.. and well be good! thanks for all the advice everyone!
another thing that was loose (not sure if it happened when i took the manifold off or just cuz...) but the PCV can (call it as you may) was out of the block... ??
Thanks Again everyone!
TJ
nus_dogg
Dec 29, 2008 08:32 PM
rx_86
10
Dec 28, 2008 09:14 PM
eskerley
13
Apr 16, 2008 02:59 PM
CHK4TIX
Jan 27, 2007 05:24 PM
Brian_92GSR
May 31, 2004 03:57 PM
