what part to put hondabond on?
nope not needed on the valve cover at all. it has this like rubber lining that goes around it. only thing i think that hondabond is really used for is the oilpan. that to my knowledge at least.
you put it on the corners by your cam gears where it goes up the lil humps on each side of the humps. just put a lil bit when you take your old one off you can tell where it was
dont use honda bond on the valve cover, its to strong for that. You can use any good quality gasket sealant found at your local hardware store. Honda bond is best used in places like the oil pan and rear main seal where no rubber gasket is used.
Shaguar47
May 28, 2007 08:47 AM
type Gendy
10
Sep 6, 2003 10:44 AM
Qwikrex
Nov 18, 2002 02:13 PM
hb_racer
Aug 4, 2002 11:58 AM
