Clicking noise when turning steering wheel?
Just had axles replaced...and I still can't figure out why everytime I turn the steering wheel, I hear a clicking noise. Anybody experiencing a similar problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gosu08 »</TD></TR><TR><TD CLASS="quote">might need to replace your cv boots...</TD></TR></TABLE>
The axles replaced were remanufactured..so it can't be the CV boot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut »</TD></TR><TR><TD CLASS="quote">Does it click when you're moving or sitting still and turning the wheel?</TD></TR></TABLE>
While sitting still and turning the wheel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR »</TD></TR><TR><TD CLASS="quote">Is the clicking noise inside the cabin? </TD></TR></TABLE>
I believe so.
I believe so.
So car off, turn the wheel and it clicks? Then I'd say bad unit(s). Try to determine which side it is first.
Also, was that "click" noise there before you replaced them? Could be something totally different all together.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Damon Reeves »</TD></TR><TR><TD CLASS="quote">Yes the clicking noise was there when the bad axles were in there.
The noise is coming from the left side of the car.</TD></TR></TABLE>
Get another reman axle and try it out. Just replace the left side this time.
I've seen Vatozone axles do the same thing right out of the box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B »</TD></TR><TR><TD CLASS="quote">
I've seen Vatozone axles do the same thing right out of the box.</TD></TR></TABLE>
I'll probably do that..if it's not the axle then I don't know..
There is still ball joints and wheel bearings. Also, just for S&G's, check the torque of the lugs...
</TD></TR></TABLE>There is still ball joints and wheel bearings. Also, just for S&G's, check the torque of the lugs...
There is still ball joints and wheel bearings. Also, just for S&G's, check the torque of the lugs...</TD></TR></TABLE>
I have been told that the ball joints and wheel bearings may need lubrication?
Could it be the reason for the loud squeaking when I reverse my car?
That doesn't mean a thing. I had to replace an axle on my civic and every time I put in a re-manufactured axle the noise and vibration didn't go away. I exchanged the axle 4 times and finally gave up. I eventually got a new oem axle and the noise and vibration went away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spids5 »</TD></TR><TR><TD CLASS="quote">
That doesn't mean a thing. I had to replace an axle on my civic and every time I put in a re-manufactured axle the noise and vibration didn't go away. I exchanged the axle 4 times and finally gave up. I eventually got a new oem axle and the noise and vibration went away.</TD></TR></TABLE>
I should have just bought OEM from the start.
Now I am broke.
I am still experiencing loud squeaking when the car motion is forward and backwards....possibly brake pads? or just the wheel bearings?
Now I am broke.I am still experiencing loud squeaking when the car motion is forward and backwards....possibly brake pads? or just the wheel bearings?
TokyoStatus
Nov 28, 2007 05:57 PM
