D16Y8 Knocking, what are the possible problems?
Old Apr 13, 2007 | 08:16 PM
c1v1c98's Avatar
Default D16Y8 Knocking, what are the possible problems?
Long story short, last July I lost a lot of oil in my D16Y8. Didn't notice until I had a bad knocking noise. It was loud. Definitely coming from the bottom end. So I ordered a b18c and just swapped it out. Now I have this d16 sitting in my garage collecting dust. I was thinking about rebuilding it and buying a some kind of older civic to throw it in for a winter beater. What possibly could the knock be? I was thinking maybe a spun rod bearing. How easy/how much money would you estimate that it would take to fix it? I know that depends on what exactly is wrong. I'm just looking for any info that I can get.
Old Apr 13, 2007 | 08:21 PM
maynards_ek's Avatar
Default Re: D16Y8 Knocking, what are the possible problems? (c1v1c98)
It is probably a spun rod bearing. Just buy a bearing set and install them yourself. Wont cost much, and you get the satisfaction of doing it yourself.
Default Re: D16Y8 Knocking, what are the possible problems? (maynards_ek)
Oh, and you might want to check your crank for scarring.
Luserkid's Avatar
Depending on how bad of a knock you might need a new crank as well as new rods.
Old Apr 13, 2007 | 08:24 PM
envee's Avatar
there is no maybe about it, if you spun and bear you will need new rods and a new crank. night as well get a new motor since its a d
Old Apr 14, 2007 | 05:59 AM
c1v1c98's Avatar
Default Re: (envee)
Anyone else?
Old Apr 14, 2007 | 06:03 AM
big-cat's Avatar
build it(if you can afford a b18c, you can prob afford to build a D.) throw like a grand or 2 into it and boost it, prob make 300whp easily and have a engine capable of 350-400ish( these are all very vague estimates lol, but somewhat true)
Old Apr 14, 2007 | 09:19 AM
BoostedRedline's Avatar
i just rebuild the bottom end of my D16Y8. the #1 rod bearing were gone and it started to walk one of the main bearing. it was a pretty significant knock. i replaced the bearing and polished the crank. it only took me maybe 2 hours to do the job. i am pretty skilled with mechanics so it wasnt a problem with me. but i think almost anyone can do that job
Old Apr 14, 2007 | 09:33 AM
92hatch_cx-t's Avatar
im actually doing this to mine right now. its a d16z6 with a y8 head. i think i spent like 180 just on the crank kit with bearings. and might as well change the piston rings or pistons....
Old Apr 14, 2007 | 10:51 AM
Farmer Brown's Avatar
Default Re: (92hatch_cx-t)
Since its out of the car, put it on an engine stand, drain the oil, take the pan off and investigate.
guessohw
Sep 20, 2012 12:06 PM
Stonewall551
Aug 6, 2012 02:31 PM
cmamtower
Mar 10, 2010 07:10 PM
Sinner
May 15, 2003 11:39 AM
