HELP ON AUDIO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slodel »</TD></TR><TR><TD CLASS="quote">black is power and red is ground</TD></TR></TABLE>
Hmmm...
Hmmm...
i believe thats reversed black is ground, red and yellow are power. try this http://www.installdr.com/Harnesses/HA-Wiring.pdf
Are you certain of this?
Let's try to be completely accurate when administering electrical advice, since incorrect information could result in damage, or worse.
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
I hope your joking. Why would you tell someone this to destroy their stuff. Karma is a bitch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vee-spec »</TD></TR><TR><TD CLASS="quote">The black is power. I recently hooked up a sony xplod unit in my ride.</TD></TR></TABLE>
funny, now you know why it does not work.
get a multimeter.... and use ur negative probe on the blk wire. black is usually ground so ur ok to test other wires with it... then u should put ur positive lead to another wire(whichever wire u think is power) and see if it has 12volts. do the same with acc power but see if 12 volts goes away when u turn the ign off. like i said black is usually ground but in toyota's it's usually brown cause black is a speaker wire. u can always just touch bare metal connected to the chassis to use as a ground as well. hopefully this helps u with ur radio and anything else u may want to try to connect power to.
92ehatch
Audio / Security / Video
16
Dec 18, 2005 09:39 PM
