HELP ON AUDIO
Old 04-13-2007, 04:01 PM
j_DC2_m's Avatar
Default HELP ON AUDIO
can anyone tell me whats the black wire on the honda audio harness? or tell me the colors of the audio harness? pleaes and thank you.
Old 04-13-2007, 04:21 PM
slodel's Avatar
Default Re: HELP ON AUDIO (j_DC2_m)
black is power and red is ground
Old 04-13-2007, 05:03 PM
EE_Chris's Avatar
Default Re: HELP ON AUDIO (slodel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slodel &raquo;</TD></TR><TR><TD CLASS="quote">black is power and red is ground</TD></TR></TABLE>
Hmmm...
Old 04-13-2007, 05:16 PM
4drSi's Avatar
i believe thats reversed black is ground, red and yellow are power. try this http://www.installdr.com/Harnesses/HA-Wiring.pdf
Old 04-13-2007, 05:30 PM
Darth ModerVader
Padawan's Avatar
Are you certain of this?
Let's try to be completely accurate when administering electrical advice, since incorrect information could result in damage, or worse.
Old 04-13-2007, 06:53 PM
slodel's Avatar
Default Re: HELP ON AUDIO (Padawan)
haha little joke
Old 04-13-2007, 08:18 PM
vee-spec's Avatar
The black is power. I recently hooked up a sony xplod unit in my ride.
Old 04-13-2007, 10:17 PM
wrx-killer-Sti-eater's Avatar
Location: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
I hope your joking. Why would you tell someone this to destroy their stuff. Karma is a bitch
Old 04-13-2007, 10:21 PM
Default Re: HELP ON AUDIO (vee-spec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vee-spec &raquo;</TD></TR><TR><TD CLASS="quote">The black is power. I recently hooked up a sony xplod unit in my ride.</TD></TR></TABLE>
funny, now you know why it does not work.
Old 04-13-2007, 11:16 PM
EG6_SI's Avatar
Im MECP certified and black is ground Red is Power and Yellow is accesorry
Old 04-14-2007, 04:20 AM
burnitdown's Avatar
red is constant, black is ground, yellow is ignition/accs. pretty much the standard for any radio
Old 04-14-2007, 04:24 AM
WihaSi's Avatar
Black is usually ground
Old 04-14-2007, 04:38 AM
perseverance's Avatar
get a multimeter.... and use ur negative probe on the blk wire. black is usually ground so ur ok to test other wires with it... then u should put ur positive lead to another wire(whichever wire u think is power) and see if it has 12volts. do the same with acc power but see if 12 volts goes away when u turn the ign off. like i said black is usually ground but in toyota's it's usually brown cause black is a speaker wire. u can always just touch bare metal connected to the chassis to use as a ground as well. hopefully this helps u with ur radio and anything else u may want to try to connect power to.
kihun_cha
11-05-2006 10:51 AM
RTW DC2R
04-20-2006 07:32 AM
92ehatch
Audio / Security / Video
16
12-18-2005 09:39 PM
romoracing
04-09-2005 11:11 AM
done
03-04-2004 04:22 PM
Quick Reply: HELP ON AUDIO
