oem wing removal.....
Old Apr 13, 2007 | 03:43 PM
vietintegboi's Avatar
Default oem wing removal.....
anyone got a DIY the stock wing removal...and how to fill the holes that left behinds......thx alot
Old Apr 13, 2007 | 03:59 PM
deadline's Avatar
weld a small covering the bottom of the hole then use bondo on top to smooth it out
Old Apr 13, 2007 | 04:48 PM
Hondas_Only's Avatar
to remove it all you have to do is remove the 4 screws holding it place underneath and then find the connector inside where the connector is hooked up. as far as filling... deadline is onpoint. you'll need a welder and to sand the area to bare metal.
Old Apr 13, 2007 | 05:03 PM
gsR_Ace20's Avatar
Default Re: (Hondas_Only)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondas_Only &raquo;</TD></TR><TR><TD CLASS="quote">to remove it all you have to do is remove the 4 screws holding it place underneath and then find the connector inside where the connector is hooked up. as far as filling... deadline is onpoint. you'll need a welder and to sand the area to bare metal. </TD></TR></TABLE>quick question since it's already a thread, is the harness to the 3rd brake light located in the wing or hatch? I'm talking about how to disconnect it thanx
Old Apr 13, 2007 | 05:34 PM
95dc2teg's Avatar
Default Re: (gsR_Ace20)
or you could just buy plugs to plug the holes after u take the wing off. I have the plugs if you want them. 10 bucks shipped.
Old Apr 13, 2007 | 06:52 PM
-Todd-'s Avatar
Default Re: (95dc2teg)
Body work is not something you just want to jump into, i'd buy the plugs.
Old Apr 13, 2007 | 07:05 PM
rockofcali's Avatar
polyester putty works like a charm put sum duck tape under the panel where the hold is and spread ur poly putty let it dry and start sanding ...on yea and make it a low spot around the holes not too deep tho...
Old Apr 13, 2007 | 08:01 PM
98GSRDC2's Avatar
Default Re: (rockofcali)
they got caps at kragen for it.
Old Apr 14, 2007 | 12:50 PM
95dc2teg's Avatar
Default Re: (98GSRDC2)
like i said if u need the plugs let me know, better than duct tape....
Old Apr 14, 2007 | 03:00 PM
EvilJunkee's Avatar
Default Re: (-Todd-)
you got pics of them plugs??
Old Apr 14, 2007 | 03:37 PM
95dc2teg's Avatar
Default Re: (EvilJunkee)
Old Apr 14, 2007 | 05:09 PM
One2NV408's Avatar
Hey I was wondering if JB Weld would work for the holes?
Old Apr 14, 2007 | 05:12 PM
kon's Avatar
kon
Default Re: (One2NV408)
tape
Old Apr 14, 2007 | 05:17 PM
SonicBluDC2's Avatar
Default Re: (kon)
Plugs are the way to go because if you change your mind, as I know we all do with our tegs you have the option of the stock wing again, Type R or a Mugen.
Old Apr 14, 2007 | 07:43 PM
My_EFsedan's Avatar
Default Re: (kon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kon &raquo;</TD></TR><TR><TD CLASS="quote">tape</TD></TR></TABLE>
yea thats what i use for my friends integra, his hatch has no holes anymore, but i learned a new way on ht, currently making a door to type r, i used sheet metal about 1x1 inch and jb welded it to the back and bondo on the top flat..ill get some pix up.
Old Apr 14, 2007 | 08:07 PM
EvilJunkee's Avatar
Thanx man, hey where can i get them?
Old Apr 14, 2007 | 09:28 PM
My_EFsedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvilJunkee &raquo;</TD></TR><TR><TD CLASS="quote">Thanx man, hey where can i get them?</TD></TR></TABLE>
my suppies came from OSH
vegaspartyy
Sep 11, 2006 09:51 PM
GetAwayDriver
Oct 14, 2004 02:46 PM
Animal-Chin
15
Mar 5, 2003 01:40 PM
AllMotorITR
Jan 18, 2003 08:32 PM
hothatch
Jun 28, 2001 01:18 AM
