car starts then dies
Old Apr 13, 2007 | 10:34 AM
NAej1's Avatar
Default car starts then dies
i recently swapped a jdm b16 into my 93 civic coupe. i can start the car but as soon as it starts, it will run for about 10 seconds then dies off. i got a code 14 off the car its the iacv. im also having to use my throttle body off my z6 because the b16 doesnt have a map sensor on it. have any ideas?
Old Apr 13, 2007 | 01:14 PM
egmatt93's Avatar
Default Re: car starts then dies (NAej1)
im gonna go with clean the iacv then put ur b16 throttle body back on and go buy a map sensor.
Old Apr 14, 2007 | 05:52 PM
19slocivic97's Avatar
Default Re: car starts then dies (egmatt93)
is the iac pin location the same on the b16 ecu???
Old Apr 14, 2007 | 06:57 PM
NAej1's Avatar
Default Re: car starts then dies (19slocivic97)
i have a 93 ex with the p28 and im also using the same wiriin harness.
Old Apr 15, 2007 | 09:55 AM
maybe try to lightlly tap on the motor side of the iac to free the pintle, some of the iacs hace a screen and sometimes it needs to have the carbon removed from it
Old Apr 16, 2007 | 03:12 PM
NAej1's Avatar
i tapped on the iacv and it changes it. and i just noticed today that on my headers the #4 exhaust pipe isnt hot at all and the others are and im pretty sure thats a misfire i just cant believe that i missed that
Old Apr 16, 2007 | 03:13 PM
NAej1's Avatar
so now that iacv code is on and i possilbly have a misfire on #4. anyone have any ideas?
eth0r
Aug 31, 2006 12:25 PM
Civic Racer X 7
11
Nov 15, 2005 05:22 PM
b16delsol
Mar 19, 2004 02:41 PM
pissedoffsol
Apr 30, 2003 08:42 PM
