Euro-R intake manifold owners...get in here!!!!
This is the diagram for the USDM h22 intake manifold. I have a Euro-R ready to install. My issue is with line #20 that goes to the EVAP purge solenoid and #24 which goes to the Constant Vacuum control valve/egr control valve.
The new manifold does not have nipples for these two lines.
I plan on removing the EGR system, so is it safe to remove the constant vacuum control valve, even though it appears it effects more than the EGR system??
Can I take out the EVAP purge solenoid and cap the charcoal canister where the line runs from the EVAP purge soenoid?? I understand that once pressure builds, this solenoid allows vapor from the gas tank to vent into the intake manifold. So if its capped off, how can the pressure be relieved.
I have no idea what do to here, and I'm pretty sure I'm the first guy locally with this setup. Really relying on you guys that have done this. Thanks
Vryantec
Jul 21, 2018 02:36 PM
Happy Gilmore
Nov 7, 2008 08:15 AM
