Tint Removal?
Old Apr 12, 2007 | 05:25 PM
99EM1's Avatar
From: Hesperia, CA... Stuck on a destroyer in VA, USA
Default Tint Removal?
The tint on my car looks like crap (its bubbling up, and purple) Shops around here want to charge me 125-160 to remove. How hard is it to remove the old tint and what would I need in order to do so. Thanks-
Old Apr 12, 2007 | 05:36 PM
Markland Photo's Avatar
https://honda-tech.com/zerosearch
i paid 100$ to get mine off
FastLife617's Avatar
Default Re: Tint Removal? (99EM1)
The way i did it on my friends car is we parked the car in a sunny area so the windows would heat up and then we took a razor peeled of the tints used Windex to wet the glue and scraped it off with the razor it wasn't hard just time consuming
Old Apr 12, 2007 | 05:37 PM
muhaMan's Avatar
not hard, i helped a friend remove his old tints on his ford escort.
all you need is a razor, BUT once you peel the tint off there will be a bunch of old dried up glue. it gets really frustrating taking it off cuz it comes off in little chunks but u can try using a hairdryer to heat the glue up and then just roll it off (not sure if it'll work)
Old Apr 12, 2007 | 05:50 PM
dumped4dr's Avatar
Default Re: Tint Removal? (muhaMan)
i used brake cleaner and the glue wiped off
(i didnt mean use brake cleaner to take off the tint... use a razor)
Old Apr 12, 2007 | 05:52 PM
WhiteOnRice's Avatar
Go to Wal-mart and (here is the tricky part) buy "tint-off." Rip the tint off, spray the glass with tint off and run a razor blade over the whole window.
Old Apr 12, 2007 | 05:57 PM
Folgers's Avatar
Default Re: (WhiteOnRice)
Only hard part is the rear window cause of the defrost.
btw dont try to burn it off, trust me its not a good idea..
Old Apr 12, 2007 | 06:00 PM
dumped4dr's Avatar
Default Re: (Folgers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Folgers &raquo;</TD></TR><TR><TD CLASS="quote">Only hard part is the rear window cause of the defrost.
btw dont try to burn it off, trust me its not a good idea.. </TD></TR></TABLE>
hahahahaha
what would give u the great idea to light a flame and stick it on something in ur car?
Old Apr 12, 2007 | 06:04 PM
haha ill take your word on that
Old Apr 12, 2007 | 06:08 PM
98GSRDC2's Avatar
Default Re: Tint Removal? (FastLife617)
there is a diy on team integra on how to take it off. go check it out
Old Apr 12, 2007 | 06:26 PM
iam7head's Avatar
Default Re: Tint Removal? (98GSRDC2)
abunch of maybe and no sure answer.
side window: windex and blade, use a heat gun, it works better than park undersun or head dryer method. heat it up evenly and you can get all the whole piece out alongs with most of the glue.
the rear/defroster: use head and windex but this time use XXX(very fine) steel wool to remove the glue, it will be mess and tiring unless you have a hatch but around 2 hours will get everything off
athoughts
Nov 28, 2005 04:47 PM
Db1 Supreme
17
Dec 29, 2003 06:31 PM
migs
Dec 3, 2002 08:07 AM
gokuson
Jun 21, 2002 01:24 PM
Kazmans94cord
Sep 23, 2001 05:05 PM
