b20 swap into ls 4dr
Old Apr 12, 2007 | 04:22 PM
REDekSI's Avatar
Default b20 swap into ls 4dr
i'm going to be helping a buddy of mine put a b20 into his LS 4dr. i'm not sure what model b20 it is but i want to know if anyone has some good input about this swap. i know i need to swap the intake manifold but what else???
Old Apr 12, 2007 | 04:40 PM
Tomdata's Avatar
Default Re: b20 swap into ls 4dr (REDekSI)
well my friend that all depends on what year B20 you got and it also depends on what year car its going into.
Old Apr 13, 2007 | 09:04 AM
REDekSI's Avatar
Default Re: b20 swap into ls 4dr (Tomdata)
its a94 integra and i guess the motor is out of a 99 cr-v so i'm guessing it would be the b20z right
Old Apr 14, 2007 | 11:02 AM
Tomdata's Avatar
use your complete intake manifold from the ls, and your distributor/altenator etc. thats it . it should be very straight forward
Old Apr 14, 2007 | 03:27 PM
REDekSI's Avatar
thats what i figured but i just wanted some input. thanks
Old Aug 10, 2007 | 07:53 PM
Red_Si's Avatar
i'm pretty sure your also going to need the ls crank pulley, i'm not sure but i've been researching because i'm about to do this swap next week and thats what i've heard
Old Aug 14, 2007 | 09:56 PM
MIMIC_INC's Avatar
Default Re: b20 swap into ls 4dr (Red_Si)
does anyone knoe if you can put a ctr or itr intake manifold on the b20 (replacing the ls one)
Old Aug 15, 2007 | 12:35 AM
SIC_jdm_da9's Avatar
i am going b20 also in a da but what im going to change are the IM TB and dizzy,altenator, ecu etc are all from the LS so yeahh.... and you will need the LS crank pulley
Old Aug 15, 2007 | 06:35 PM
MIMIC_INC's Avatar
Default Re: (SIC_jdm_da9)
why would you change that???
Old Aug 15, 2007 | 07:02 PM
LordAphotic's Avatar
Default Re: (MIMIC_INC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIMIC_INC &raquo;</TD></TR><TR><TD CLASS="quote">why would you change that???</TD></TR></TABLE>
if your asking why would you change the crank pulley its because of its size. the b20 has a much larger alternator loop. which creates too much electricity in higher rpms that can possibly damage your alternator or other things.
because of the size of the b20 crank pulley a lot of people with superchargers will switch to the b20 crank pulley cause it will create more psi.
I own two tegs both with b20s. one turbo, one stock.
switching the crank pulley isnt mandatory. but if you dont switch it your going to have to find a belt that will properly fit the b20 crank pulley and the integra alternator/PS/AC. i found it from a ford car but im not sure which one cause ive switched my pulley back to the LS one when i did my timming belt.
U have to switch the intake manifold and everything attached to it. the distributor and thats it. some b20 blocks have a different drivers side top mount... so you might have to switch the mount from your ls block to the b20 block...
I usually dont give out freebies like this cause i get mad that all this information is already out on honda tech and team integra so it makes me mad that people keep asking this same question over and over....
but a lot of people are talking on this thread so i thought i would say what im saying before lots of bad information starts rolling in.
Old Aug 15, 2007 | 09:17 PM
PACT man's Avatar
Default Re: (LordAphotic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LordAphotic &raquo;</TD></TR><TR><TD CLASS="quote">
but a lot of people are talking on this thread so i thought i would say what im saying before lots of bad information starts rolling in.</TD></TR></TABLE>
^^^I think he covered pretty much everything very well. I think you will need to use the timing belt side mount bracket from the block, not completely sure though. Everyones saying complete IM, but just to make sure that includes the fuel rail and everything there also. Another little thing is that you will be switching the PCV system setup from the breather box on the block to the one in the valve cover, so you'll probably need to get a little bit of hose and a PCV valve for a 98+ Integra or 99-00 CR-V. I think you'll probably have the extra crank pulley sensor and knock sensor on the B20 block that you won't be using.
Old Aug 16, 2007 | 04:39 PM
MIMIC_INC's Avatar
Default Re: (PACT man)
o rite...rite i guess from my stupidity i just wrote without reading exactly what he said but thanks for the whole write up
1994delsolLS
14
Jan 6, 2025 10:55 AM
bettsbanger
Sep 19, 2009 12:09 PM
B20_EG8
May 3, 2007 01:22 PM
sixfiveoh
Jan 10, 2007 10:40 AM
redDAinteg
Oct 18, 2006 10:29 AM
