Are all B-series starters compatible?
Old Apr 12, 2007 | 10:06 AM
ericlee303's Avatar
Default Are all B-series starters compatible?
Did a search but couldn't find anything solid. Sorry if I missed something!
Are all B-series starters compatible? Specifically, are the contacts inside all compatible? There is no way I'm paying $300 for a new one from Honda!
Thanks!
Eric
Old Apr 12, 2007 | 12:05 PM
len's Avatar
len
Default Re: Are all B-series starters compatible? (ericlee303)
Most of the plugs are interchangeable. They will physically fit in most cases, but if the starter gear teeth doesn't match the teeth pattern on the flywheel, you may have some issues.
Old Apr 12, 2007 | 12:26 PM
D's Avatar
D
AFAIK, all B starter solenoid contacts are the same. Last time i bought the contacts only, IIRC, $3 ea. at local starter/alternator rebuild place.
Old Apr 12, 2007 | 07:07 PM
94rs-turbo's Avatar
as long as its b-series manual
Old Apr 12, 2007 | 08:58 PM
R you serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ericlee303 &raquo;</TD></TR><TR><TD CLASS="quote">
Are all B-series starters compatible? </TD></TR></TABLE>
cable tranny one are dif. from my expierence
Old Apr 13, 2007 | 01:53 AM
tartje's Avatar
Default Re: Are all B-series starters compatible? (R you serious)
i know the starter gear teeth differ slightly from US and JDM models, as when people have bought spoon flywheels they occasional have grief
Old Apr 13, 2007 | 05:55 AM
H-PIMP's Avatar
Default Re: Are all B-series starters compatible? (tartje)
'94 and up B series manual should be physically the same, plugs vary by year clusters.
Old Apr 13, 2007 | 06:32 AM
ericlee303's Avatar
Thanks guys, a friend mech told me that some starters aren't rebuildable, if you can't take the end cap off the casing where the solenoid is. Is that true?
JerseySiPOS
Northeast (Sales)
Dec 29, 2013 11:16 AM
BIGGMIKEE
Texas -OK -LA (Sales)
Nov 4, 2010 03:08 PM
T3KNiQe
Nov 22, 2008 01:51 PM
Miknow
Nov 7, 2005 09:59 PM
