92-95 Civic Hatchback Specifications CX DX VX Si
Old Apr 12, 2007 | 10:01 AM
hardEH2's Avatar
Default 92-95 Civic Hatchback Specifications CX DX VX Si
Just thought this would be nice to have, may be it could be thrown into FAQs.
Listed below are Honda's Manufacturing Specifications on our beloved hatches, it will list everything from engine code to drivetrain, dimensions to brakes.
Lets get started
Civic CX, DX, VX (all categories with respect to model)
Engine
Engine Code: D15B8 / D15B7 / D15Z1
Type: Inline-4, Aluminum Block and head, SOHC, 2 Valves per cylinder
Inline-4, Aluminum Block and head, SOHC, 4 Valves per cylinder
Inline-4, Aluminum Block and head, SOHC, 4 Valves per cylinder w/ VTEC-E
Displacement: 1493 cc
Bore & Stroke: 75.0 mm x 84.5 mm
Compression Ratio: 9.1:1 / 9.2:1 / 9.3:1
Horsepower: 70hp @ 5000 / 102hp @ 5900 / 92hp @ 5500
Torque: 91 lb-ft @ 2000 / 98 lb-ft @ 5000 / 97 lb-ft @ 4500
Drivetrain
Manual Five-Speed w/ starter interlock
Gear Ratios (CX)
1: 3.250:1
2: 1.761:1
3: 1.066:1
4: 0.852:1
5: 0.702:1
Final Drive: 3.250:1
Differential: Open
Gear Ratios (DX)
1: 3.250:1
2: 1.761:1
3: 1.172:1
4: 0.909:1
5: 0.702:1
Final Drive: 4.060:1
Differential: Open
Gear Ratios (VX)
1: 3.250:1
2: 1.761:1
3: 1.066:1
4: 0.852:1
5: 0.702:1
Differential: Open
Exterior Dimensions
Curb Weight: 2108 lbs / 2178 lbs / 2094 lbs
Weight Distribution: 62/38 / 61/39 / 62/38
Overall Length: 160.2 inches
Wheelbase: 101.3 inches
Overall Width: 66.9 inches
Height: 50.7 inches
Suspension (all models)
Front: Independent Double Wishbone w/ coil springs and 21mm anti-roll bar
Rear: Independent Double Wishbone w/ trailing arms and coil springs
Brakes
Front: Ventilated discs, 9.45 inch, vented rotors, power assist
Rear: Drum
Wheels & Tires
Wheels: 13 x 5-inch steel
Tires: 165/70-R13
Si Model
Engine
Engine Code: D16Z6
Type: Inline-4, Aluminum Block and head, SOHC, 4 Valves per cylinder w/ VTEC
Displacement: 1590 cc
Bore & Stroke: 75.0 mm x 89.9 mm
Compression Ratio: 9.2:1
Horsepower: 125 hp @ 6600
Torque: 106 lb-ft @ 5200
Drivetrain
Gear Ratios
1: 3.250:1
2: 1.900:1
3: 1.250:1
4: 0.909:1
5: 0.702:1
Differential: Open
Exterior Dimensions
Curb Weight: 2390
Height: 50.7 inches
Brakes
Front: Ventilated discs, 10.38 inch, vented rotors, power assist
Rear: 9.43 inch solid discs
Wheels & Tires
Wheels: 14 x 5- inch steel, wheel covers
Tires: 184/60-R14
Hope I'm not missing anything and I hope this helps you guys with references!
Peace
-Jimmy
Old Apr 12, 2007 | 10:11 AM
Archidictus's Avatar
Unceasing Measure
Default Re: 92-95 Civic Hatchback Specifications CX DX VX Si (hardEH2)
https://honda-tech.com/zerothread/642479
Old Apr 12, 2007 | 10:47 AM
hardEH2's Avatar
Default Re: 92-95 Civic Hatchback Specifications CX DX VX Si (Archidictus)
werd, i should read more.
Old Apr 12, 2007 | 11:24 AM
HXvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread/642479</TD></TR></TABLE>
lol i knew he was gonna to this too.
Old Apr 12, 2007 | 08:28 PM
deadline's Avatar
good stuffer
Old Apr 19, 2007 | 12:11 PM
JMelt4's Avatar
I don't think the 92 - 95 DX's have 21mm front sways.....can anyone confirm?
Old Apr 19, 2007 | 12:19 PM
kaiba's Avatar
Default Re: 92-95 Civic Hatchback Specifications CX DX VX Si (JMelt4)
For the hatch model only the Si had front sway.
pinks11
Dec 25, 2008 06:47 PM
crxjarred
Dec 18, 2008 03:15 AM
phoeg6
30
Sep 9, 2005 08:36 PM
HondaRacer32
Jan 29, 2004 03:06 PM
CivilizedCiv
May 1, 2002 08:56 AM
