D16y8 or z6????????
Old Apr 12, 2007 | 08:10 AM
97elitehonda's Avatar
Default D16y8 or z6????????
I'm about to get another engine and put new pistons, rods, and all that good stuff and i need some advice on whether i should get the y8 or z6? i am lookin for about 400bhp. im definatly goin to boost too. any advice would be awesome. thanks.
Old Apr 12, 2007 | 08:16 AM
gezzuzz's Avatar
Default Re: D16y8 or z6???????? (97elitehonda)
what ever one you can get cheaper.. or the one with the lowest mileage
Old Apr 12, 2007 | 08:21 AM
HXvtec's Avatar
400bhp. you got to be kidding me. your not going to get close with either of those motors.
Old Apr 12, 2007 | 08:27 AM
Default Re: D16y8 or z6???????? (HXvtec)
i didnt mean bhp i just meant hp all around.? c i have the stock d16y8 in my car now but its in bad shape and has 225,000 on it. i heard that with the z6's you can get about 400hp out of it after you boost (i dont know how much) and get a real good tune on it . but i mean i would be rebuilding it with new everything pretty much.
Old Apr 12, 2007 | 08:31 AM
does anyone have any reccomendations on what to parts to buy so i can reach my goal of 400hp with the z6 or y8?
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97elitehonda &raquo;</TD></TR><TR><TD CLASS="quote">i didnt mean bhp i just meant hp all around.? c i have the stock d16y8 in my car now but its in bad shape and has 225,000 on it. i heard that with the z6's you can get about 400hp out of it after you boost (i dont know how much) and get a real good tune on it . but i mean i would be rebuilding it with new everything pretty much.</TD></TR></TABLE>
You're definitely going to have to research a lot if you plan on reaching 400whp, as well as doing a complete buildup of either of those motors.
I would definitely go with the z6. Im in the process of building a z6 from the bottom - up for 400whp...actually, im almost done
Old Apr 12, 2007 | 08:33 AM
Default Re: D16y8 or z6???????? (1995Civic)
what all did you do to it?
Old Apr 12, 2007 | 08:39 AM
.Sarge.'s Avatar
Get the z6.
I would personally get Eagle H-beams and Vitara Pistons. Get a cam and Valve springs and a Intake manifold and really good tuning and all the fuel goodies and 400whp isnt out of the question.
Old Apr 12, 2007 | 08:42 AM
h2392si's Avatar
Default Re: D16y8 or z6???????? (_.Sarge._)
I have both, basically same motors. Just get the one with the lowest price.
Old Apr 12, 2007 | 08:45 AM
.Sarge.'s Avatar
Default Re: D16y8 or z6???????? (h2392si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2392si &raquo;</TD></TR><TR><TD CLASS="quote">I have both, basically same motors. Just get the one with the lowest price. </TD></TR></TABLE>
The y8 can be harder to tune due to the timing of the motor.
y8/=z6
Old Apr 12, 2007 | 09:01 AM
what else do you think i need for the z6 besides the eagle H-beams Virtara Pistons and a cam and valve springs and intake manifold? i definatly want to boost it. any suggestions on what psi i should boost and what turbo i should get? i think im just gunna keep my y8tranny and use it cause its in real good shape and the gears dont grind. i might want to get a new clutch and flywheel. the top of the z6 was just takin off and rebuilt so its just like new, its just the bottom has somewhere around 180,000 on it. is that gunna be a good buy for like $400.00?(as you can tell i need a lot of help cause i dont really know what to do or what im doin, but everybody has got to start somewhere right?)
Old Apr 12, 2007 | 09:28 AM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97elitehonda &raquo;</TD></TR><TR><TD CLASS="quote">what else do you think i need for the z6 besides the eagle H-beams Virtara Pistons and a cam and valve springs and intake manifold? i definatly want to boost it. any suggestions on what psi i should boost and what turbo i should get? i think im just gunna keep my y8tranny and use it cause its in real good shape and the gears dont grind. i might want to get a new clutch and flywheel. the top of the z6 was just takin off and rebuilt so its just like new, its just the bottom has somewhere around 180,000 on it. is that gunna be a good buy for like $400.00?(as you can tell i need a lot of help cause i dont really know what to do or what im doin, but everybody has got to start somewhere right?)</TD></TR></TABLE>
Ok here we go...
Vitara pistons are a great way to get into the 300whp range without spending a fortune. The Eagle H-beam rods are going to require you to notch the cylinder walls to be able to fit. This is a very easy process, any machine shop can do it...even you. They are great rods though, and can easily handle 300+
You're not gonna get $400 for that y8 block that you have, so i wouldnt even bother with that. If your z6 head is rebuilt to stock, thats fine. Just replace the cam with a Zex 59300 (stage 2)...you technically don't HAVE to change out the springs with this cam, however i would recommend it. Stock z6 heads minus an aftermarket cam, have made 400whp all day long with a built block.
You will most definitely need to change the clutch too. Some options are Action, Exedy Stage 3, ACT. You dont necessarily have to get a lightened flywheel, you will just need to have your stock one resurfaced (at a machine shop).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97elitehonda &raquo;</TD></TR><TR><TD CLASS="quote">what all did you do to it? </TD></TR></TABLE>
My setup is as follows:
z6 Head:
Mild Port and Polish (Intake and Exhaust)
Cometic MLS 75mm HG
ARP Headstuds
Crower Valvesprings
Crower TI Retainers
Crower SS Valves
Zex 59300 Cam
Port Matched IM w/ 68mm BDL TB
z6 Block:
Stock Sleeves (at least for now)
Honed
CP 9:1 Pistons
Crower Rods w/ ARP rod bolts
GE BlockGuard (still debating)
Thats a little more than basic for a build, however i have specific goals.
Also, i have an Exedy Stg 2 clutch. (Cerametallic)
Old Apr 12, 2007 | 09:29 AM
suspendedHatch's Avatar
You're going to need some real engine management, like an AEM EMS. Not any chipped ECU or piggyback bullshit.
Old Apr 12, 2007 | 09:32 AM
1995Civic's Avatar
Default Re: D16y8 or z6???????? (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">You're going to need some real engine management, like an AEM EMS. Not any chipped ECU or piggyback bullshit.</TD></TR></TABLE>
Yea exactly.
Theres many things i left out, but the list i gave you will be plenty to work on for now.
I didnt even get to the Engine Management, turbo setup, or tuning....theres still a long way to go.
Old Apr 12, 2007 | 09:49 AM
.Sarge.'s Avatar
What are your plans for the car?
Do you want a wide powerband?
Or lots of Top end?
Old Apr 12, 2007 | 09:50 AM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _.Sarge._ &raquo;</TD></TR><TR><TD CLASS="quote">What are your plans for the car?
Or lots of Top end?</TD></TR></TABLE>
Sorry bro...was this question directed to me?
Old Apr 12, 2007 | 11:51 AM
sleepyhouse1422's Avatar
check out http://www.d-series.org lots of good info
Old Apr 12, 2007 | 09:03 PM
1995Civic's Avatar
If this question was for me...
Im looking for 350+ whp, so im not really sure yet what turbo setup ill be going with yet. I think i have my sights set on the SC61 though...so ill probably be looking to get more top end...I have a pretty wide powerband right now on my t3 super 60
EH6TunerDaniel
Jan 25, 2007 12:22 PM
mugencivic94
Dec 14, 2005 03:30 PM
Curbow_USMC
Aug 16, 2005 09:36 AM
litterbox
28
Feb 25, 2005 12:55 PM
EJ6-
Aug 20, 2003 11:01 AM
