Blue Smoke
Old Apr 11, 2007 | 04:16 PM
jit01's Avatar
Default Blue Smoke
I is it normal for a b16a3 to burn oil when in vtec ? I see a little bit of blue out of the exhaust when I go into vtec.
I have a 95 del sol vtec.
Old Apr 11, 2007 | 04:19 PM
schardbody's Avatar
normal NO, usual, yes, its usually valve guides if its only at high RPMS.
Old Apr 11, 2007 | 04:21 PM
jit01's Avatar
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">normal NO, usual, yes, its usually valve guides if its only at high RPMS.</TD></TR></TABLE>
And how much is it to replace ? Also yes its only when I go into vtec.
Old Apr 11, 2007 | 04:24 PM
schardbody's Avatar
whatever the price of a head job cost, depends if you pull the head yourself and take it to the machine shop ect.
dont rule out other things though. changing the PCV valve wont hurt, as it could cause the same thing, and only cost $2.
Old Apr 11, 2007 | 06:52 PM
lbcracing's Avatar
um check how much oil you ahve in there. if its tooo much, it will "boil" at high rpms and burn around the rings. sounds like too much oil or needs an oil change. i would say the Rings are bad on your cylinder walls. change the oil and only put 3.9 quarts in this time
Old Apr 11, 2007 | 11:20 PM
jit01's Avatar
Default Re: (lbcracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lbcracing &raquo;</TD></TR><TR><TD CLASS="quote">um check how much oil you ahve in there. if its tooo much, it will "boil" at high rpms and burn around the rings. sounds like too much oil or needs an oil change. i would say the Rings are bad on your cylinder walls. change the oil and only put 3.9 quarts in this time </TD></TR></TABLE>
I think you are right.. I put a bit too much oil in this time and I do need an oil change lol. I read around and people do say vtec does burn a bit of oil I have noticed that too thats why I put in some more oil (ended up being a bit too much)
You think if I change the oil it would fix this problem ?
Old Apr 11, 2007 | 11:46 PM
jit01's Avatar
Default Re: (jit01)
Guys what color is the oil supposed to look like on the dipstick ? I just bought this car in like jan and I am not sure if they even changed it (they said they did)
Old Apr 12, 2007 | 03:17 AM
ek9tl's Avatar
Default Re: (jit01)
u serious..?it suppose to look like new oil from the store..lightbrown..NOT BLACK!!!MAN JUST CHANGE THE OIL!!!!
Old Apr 12, 2007 | 04:55 AM
simonsays's Avatar
New User
^ amen
Old Apr 12, 2007 | 04:19 PM
schardbody's Avatar
wow, yeah, vtec engagement causes oil to burn, umm, sure that might be what people think, but its not the truth.
and being a 1/2 quart or a little more overfull isnt going to cause oil consumption either.
Old Apr 12, 2007 | 04:23 PM
-Todd-'s Avatar
Default Re: (jit01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jit01 &raquo;</TD></TR><TR><TD CLASS="quote">Guys what color is the oil supposed to look like on the dipstick ? I just bought this car in like jan and I am not sure if they even changed it (they said they did)</TD></TR></TABLE>
lol What color is the oil supposed to be? I might put that in my sig.
Old Apr 13, 2007 | 01:31 PM
ek9tl's Avatar
Default Re: (-Todd-)
lol thats just tooooo fckin funny!!!
Black R
Mar 28, 2011 05:42 PM
Vtec4me
Aug 4, 2006 06:49 AM
Mag00n
Sep 24, 2005 08:12 AM
gsr_to_the_MAX
Oct 19, 2004 11:15 PM
stockgreencivic
Apr 26, 2003 02:41 AM
