Battery Keeps dying
Old Apr 11, 2007 | 04:13 PM
sinceDAY1_95civic's Avatar
Default Battery Keeps dying
My car died sometime last week in a parking lot. I was driving and when i hit the brakes the radio shut off, and then my rpm guage droped to zero and wouldn't move while the car was still running. When i got to a stop sign i shut the car off and it couldn' t start back up, my hazards wouldn't even go on. I put a new battery in, and it was fine for two days and it happened a again this time while i was driving, Hit the brakes and the radio shut of then everything died. ???????????????????Is this an alternator problem of something bigger. Oh i have a 95 civic coupe ex stock d16.
Old Apr 11, 2007 | 04:59 PM
ennah's Avatar
Default Re: Battery Keeps dying (sinceDAY1_95civic)
Your alternator is probably the cause of this
Old Apr 11, 2007 | 05:01 PM
chansaephanh's Avatar
alternator causes battery to drain so check that
Old Apr 11, 2007 | 06:47 PM
lbcracing's Avatar
Default Re: (chansaephanh)
the alternator will drain the battery and a short in the wires will make everything else mess up. whnen you step ont he breaks, the radio will shut off if the battery is dead. like if you try to drive with the neg terminal unplugged it will do the same thing. sounds like a short and alternator replaced will fix it.
Old Apr 11, 2007 | 06:51 PM
h2392si's Avatar
Default Re: (lbcracing)
Yup, change the alternator and all will be fixed.
Old Apr 11, 2007 | 07:04 PM
maynards_ek's Avatar
Default Re: (h2392si)
Most parts stores will check your battery for free. If you get a new alternator, and the battery is still draining, then you have a voltage leak somewhere.
Old Apr 11, 2007 | 07:12 PM
spoon_ek9's Avatar
hook up a voltmeter to check the voltage at the battery when the car is running, if it is anything above 13.5v, then the alternator is charging and your battery is no good. OR put the voltmeter into amp mode and check if there is any draw after the car is shut off. if there is amp after everything is shut off, then something in your car is drainning the battery out, in that case, neither the battery nor the alternator is faulty.
Old Apr 11, 2007 | 07:16 PM
bottle-fed-bitch's Avatar
Check water in battery? maybe low? some alternator shops will also check alternator for free too, try to locate them first.
Old Apr 11, 2007 | 07:18 PM
Default Re: Battery Keeps dying (spoon_ek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon_ek9 &raquo;</TD></TR><TR><TD CLASS="quote">hook up a voltmeter to check the voltage at the battery when the car is running, if it is anything above 13.5v, then the alternator is charging and your battery is no good. OR put the voltmeter into amp mode and check if there is any draw after the car is shut off. if there is amp after everything is shut off, then something in your car is drainning the battery out, in that case, neither the battery nor the alternator is faulty.</TD></TR></TABLE>
Smart too.
disposable
Jun 26, 2008 08:02 PM
Scud
Feb 28, 2008 03:35 PM
Fatty_1775
Oct 23, 2002 02:33 AM
Martaigne
Jul 14, 2002 04:19 PM
