This is the Last Straw!!
Old Apr 11, 2007 | 11:55 AM
DrewMD's Avatar
Davis Photography
Default This is the Last Straw!!
I'm sick and tired of throwing the IACV light. I did a manual tranny conversion which needed the 3 to 2 wire IACV change. so I did. I have to reset my ECU every couple of days because it will randomly start to act up. Once this problem randomly instantly occurs I can fix it temporarily by turning the car off then back on.
I checked my wiring and its was fine. its rewired right at the ecu too. The IACV is still good bc it clicked when power was put on it.
please help!
Old Apr 11, 2007 | 01:17 PM
97Ej6mike's Avatar
Naturally, if a civic has a 3 wire IAC, its not a good idea to try and swap it to two wire... mainly based on the fact a 3 wire IAC runs on a different operation than a 2 wire one does in mechanical terms. Ive read up on ppl claiming theres a way to bypass it, but i really dont buy into that, cause i have yet to see any sucess stories.
If you want to make it run right, get the correct wiring harness and correct ECU that reads for a 2-wire operating IAC.
The only 3-wire IAC i know of is the D16Y7 (96-00 LX, DX, HX)
Anything else ive seen runs a standard two-wire IAC on the back of the manifold.
Old Apr 11, 2007 | 01:55 PM
DrewMD's Avatar
Davis Photography
I have a 5 spd manual tranny for that correct motor. it only runs on the two wires. it said to remove one and move another wire to the correct spot. thats what i did.
Old Apr 11, 2007 | 02:32 PM
EE_Chris's Avatar
Default Re: (DrewMD)
Can you take a picture of your wire job?
Old Apr 12, 2007 | 01:42 PM
DrewMD's Avatar
Davis Photography
which would you like? ive got the two wires in the bay taped up. i can take a pic of the engine harness plugs.
any other stuff lmk.
Old Apr 12, 2007 | 03:55 PM
EE_Chris's Avatar
Let's see the whole enchilada. Un-do the electrical tape and let's see what it looks like beneath it.
Old Apr 13, 2007 | 03:02 PM
DrewMD's Avatar
Davis Photography
ok. ill post the pics up real quick.
Old Apr 13, 2007 | 03:22 PM
DrewMD's Avatar
Davis Photography
here they are:
I sodered the one wire in the bay. it will be fine for a day or two then go bad.
Old Apr 13, 2007 | 03:31 PM
DrewMD's Avatar
Davis Photography
I believe it could be that when I tried a different IACV air got trapped at the top of the cooling passage right above where the two coolant lines go into. this would cause the coolant not to circulate properly causing the unit to over heat and not work properly. thats what i think it is.
I heard that you couldnt burn out the IACV unit in the ecu.
Old Apr 13, 2007 | 04:25 PM
EE_Chris's Avatar
Solder your wires. Why did you only solder one anyway? It looks like a pretty cold joint....I can see why it'd keep breaking.
Old Apr 13, 2007 | 04:40 PM
instrument's Avatar
at the very least man shrink wrap it, i'm a little **** about wiring so that looks a bit ridiculous.
Old Apr 13, 2007 | 04:42 PM
EE_Chris's Avatar
Default Re: (instrument)
Well, to his defense, I did ask him to take off any electrical tape he had over it...
Old Apr 13, 2007 | 04:52 PM
-JSpecEk*9-'s Avatar
Default Re: (EE_Chris)
do it right and fix those wires asap!
Old Apr 13, 2007 | 04:53 PM
Si_chRis's Avatar
Default Re: (-JSpecEk*9-)
Use crimps if you don't know how to solder the wires...twisting them is not so good.
fix that ASAP! not the right way to do wiring.
Old Apr 13, 2007 | 06:28 PM
JokerX-1.6T's Avatar
call me stupid but Ill throw this out anyway did you swap the intake manifold from a auto intake mani to a manual intake manifold ? I see you saying you did a manual conversion but I havent heard anything about the intake mani . Like I said I assume you did but I just have to ask
Old Apr 13, 2007 | 08:45 PM
DrewMD's Avatar
Davis Photography
Yes, I did swap over the manifold. I'm definently going to have to sharpen my soldering skills. What do you mean by a cold joint? and breaking as in the electrical current?
If I were to retry... do I twist the wires like above then solder?
Modified by DrewMD at 12:02 AM 4/14/2007
Old Apr 14, 2007 | 02:55 AM
EE_Chris's Avatar
Give this a read. You can probably start towards the bottom on the "General Methodology" part.
Old Apr 14, 2007 | 05:58 AM
big-cat's Avatar
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">Naturally, if a civic has a 3 wire IAC, its not a good idea to try and swap it to two wire... mainly based on the fact a 3 wire IAC runs on a different operation than a 2 wire one does in mechanical terms. Ive read up on ppl claiming theres a way to bypass it, but i really dont buy into that, cause i have yet to see any sucess stories.
Anything else ive seen runs a standard two-wire IAC on the back of the manifold.</TD></TR></TABLE>
i would actually listen to what this guy has to say and get a ecu for the manual version of your car, and get the wiring harness for the manual version of your car, expensive but will fix everything(sorry i didnt hear you say what your engine was). yeah i did something similar to yours, and in the long run, your like " wtf i could of just done a whole motor swap and it would be the same price(d16z6 that is or a better d-series). well learn from your mistakes, thats why we make them.
Old Apr 14, 2007 | 07:12 AM
Silvertc's Avatar
Default Re: (big-cat)
get a DIFFERENT ECU, as in a Manuel
Old Apr 14, 2007 | 11:15 AM
97Ej6mike's Avatar
Default Re: (jdmjr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjr &raquo;</TD></TR><TR><TD CLASS="quote">get a DIFFERENT ECU, as in a Manuel </TD></TR></TABLE>
X2
Old Apr 14, 2007 | 11:35 AM
DrewMD's Avatar
Davis Photography
learn to read. I do have the correct ecu.
thanks EE_Chris for the help.
Chaosgrunt
Mar 13, 2019 06:23 PM
santii7
Jun 21, 2011 07:22 AM
IDriveHonda
Apr 13, 2008 06:13 PM
drew2
Dec 7, 2005 07:40 PM
Sketch_hs
Aug 19, 2004 08:44 AM
