Headlight delay when turned on.
Old Apr 11, 2007 | 05:05 AM
Preferio's Avatar
Default Headlight delay when turned on.
This is no huge issue or anything, but it's just annoying me... Whenever I turn my headlights on, the drivers side light will come on about 2 seconds after the passenger side comes on. It started doing this two months ago. Any ideas?
Old Apr 11, 2007 | 05:19 AM
t0p_sh0tta's Avatar
Default Re: Headlight delay when turned on. (PreFerio)
Check to make sure the harness isn't all corroded and whatnot on the driver's side.
Old Apr 11, 2007 | 09:38 AM
BlackoutVTi's Avatar
Default Re: Headlight delay when turned on. (t0p_sh0tta)
Possibly loose connection to the bulbs through the rubber guards. If the connectors are locked in, but still kinda jiggle around, use a pair of needle nosers and tighten them till they make a good fit, or tug gently on the wires until they make tension, causing a good connection through the grommet. It's hard for me to explain, but I had exactly this problem before, and I did the latter to fix it. No problems, going on 3 months now.
hotaccord243
May 29, 2008 01:00 PM
Senbonzakura
Jan 4, 2005 07:48 PM
Accorddrver
Apr 27, 2004 09:41 AM
Zohigh
Jan 6, 2003 06:42 AM
