Power windows and Power door locks???-HELP-!!!
Old 04-10-2007, 05:21 PM
94Hatchd15b7's Avatar
Default Power windows and Power door locks???-HELP-!!!
I search and search but no luck . I have a 1994 Dx hatchback that I would love to put power windows and doorlocks into it. I live by a couple of good junkyards so I can get what I need out of an Ex coupe. My qestion is, can I bolt up and wire up 1994 Ex coupe power windows and doors locks into it. Like all the internal parts? Will all Ex coupes 92-95 bolt up? Or what about 96-99 Ex coupe bolt up.
Old 04-10-2007, 05:48 PM
ricerEJ8's Avatar
Default Re: Power windows and Power door locks???-HELP-!!! (94Hatchd15b7)
im not sure but for EK hatches u need the EX floor harness as well as the doors for it to work...its probably the same for 92-95
Old 04-10-2007, 05:54 PM
dad0c402's Avatar
Default Re: Power windows and Power door locks???-HELP-!!! (ricerEJ8)
It totally possible and bolts right up, just makes sure you have everything you need. The floor harness isn't totally necessary if you can't get one but helps alot.
You basically need everything one the door but the metal of the door, glass, handle, and rubber. Which leaves Door panel with all switches and plastic peices,door harness, power window assembly, lock actuator, lock box, floor harness (not totally needed but makes it plug and play), and the power door relay with fuses off the under dash fuse box.
Old 04-10-2007, 06:01 PM
ricerEJ8's Avatar
Default Re: Power windows and Power door locks???-HELP-!!! (dad0c402)
how would u do it without the floor harness?
Old 04-10-2007, 08:16 PM
melsers's Avatar
you dont need the window glass its the same for manual or power windows
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricerEJ8 &raquo;</TD></TR><TR><TD CLASS="quote">how would u do it without the floor harness?</TD></TR></TABLE>
you would need to ghetto rig your own wiring harness
Old 04-10-2007, 08:44 PM
dad0c402's Avatar
Default Re: Power windows and Power door locks???-HELP-!!! (melsers)
melsers hit the spot. I'm actually doing it right now, running my own wires with my own little fuse box and a relay to control the power to the windows when the key is in.
Old 04-10-2007, 08:46 PM
jdm_junkie9's Avatar
When I did it on my ek i just swapped doors from the ex, i noticed ya need some wiring and switches.
Old 04-11-2007, 09:39 AM
I'll give it a try dad0c402 I think it will work
RustyE.G.
08-31-2012 10:12 AM
Saiyan_Jin_Goku
10-07-2007 12:07 AM
boston's_rex
07-17-2006 09:24 AM
MIZIKETSK
09-06-2002 06:55 PM
FifthGearOnline
10-20-2001 02:38 AM
Quick Reply: Power windows and Power door locks???-HELP-!!!
