complete ek suspension swap to an eg.. does it fit fine?
I heard most suspension parts fit onto an EG except for the rear LCAs.. but when swapping a FULL suspension to an EG, does it fit fine? what do I/do I not need?
I searched but nothing I was looking for.. maybe I didn't search hard enough.
but I couldn't find much.
Thanks in advance.
but I couldn't find much.Thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoya_10fintec »</TD></TR><TR><TD CLASS="quote">I heard most suspension parts fit onto an EG except for the rear LCAs.. but when swapping a FULL suspension to an EG, does it fit fine? what do I/do I not need?
Thanks in advance. </TD></TR></TABLE>
the suspension parts that are swappable are for dc/eg Honda's. the ek's have some compatibility, but not as much as dc's/eg's.
the rear trailing arm and brakes are swappable, just keep your existing lca.
but I couldn't find much.Thanks in advance. </TD></TR></TABLE>
Thanks
but all I have in Korea is a wrecked 99 Civic and I have to use the suspension parts off of that civic on to the EG. what I really need is the front LCA's
can I use FRONT lower arms? if so, what else do I have to swap or use or modify? Or can I swap the whole/complete suspension including the subframe?
Thanks again
Thanks again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoya_10fintec »</TD></TR><TR><TD CLASS="quote">Thanks
Thanks again</TD></TR></TABLE>
no the front LCA are different as well. you can swap out brake stuff. all depending on what model civic you have and the 99 civic.
as for parts, japan is right around the corner, don't they have like websites or contacts that can benefit you? and you know there is always ebay.
