New motor, rough idle, lots of smoke.
Old Apr 10, 2007 | 05:45 PM
SiRay13's Avatar
Default New motor, rough idle, lots of smoke.
Im trying to figure out why my motor is burning so much gas, I'll have it on for maybe 20 seconds and the whole garage will be full of gas fumes, where should i start looking? This is a d16a6 with a jrsc. The idle is also really rough.
Old Apr 10, 2007 | 09:12 PM
EF_LSVtec's Avatar
Default Re: New motor, rough idle, lots of smoke. (SiRay13)
Maybe you can post up your entire set up...so we can help. Without it, we're simply guessing.
what injectors? fuel pump? ecu? Any internal mods? Do you have an adjustable fuel pressure regulator?
Old Apr 11, 2007 | 07:33 AM
Ya SiR!'s Avatar
Default Re: New motor, rough idle, lots of smoke. (EF_LSVtec)
Hey man, I switched out my engine too and had that same problem. two thing caused that to be happening for me. 1 was the map sensor and two for the rough idle was caused by the cold start . . . there is a plastic screw like thing in it that has a bad habit of backing out. I pulled it down and had put silicone so it wont do that any more and screwed it all the way back in . . . check those out and see if that what causeing it . . .
Old Apr 11, 2007 | 07:40 AM
ludesrv's Avatar
Post your setup please.
But my guess is:
Too much fuel from bad tuning of setup, so much fuel it bogs at idle real bad.
Pull your plugs, they wet from gas?
Old Apr 11, 2007 | 09:01 AM
SiRay13's Avatar
Default Re: (ludesrv)
here's the set up, D16a6
right now it has stock injectors, adjustable fpr, im at 42psi, walbro highflow 250lph pump, exospeed stage two cam, head has new valves, guides, ported/polished, endyn rollerwave pistons, eagle rods, ported jrsc, 8lb flywheel, clutchmasters stage3 clutch. what else do you need to know?
Old Apr 11, 2007 | 09:05 AM
ludesrv's Avatar
Default Re: (SiRay13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRay13 &raquo;</TD></TR><TR><TD CLASS="quote">here's the set up, D16a6
right now it has stock injectors, adjustable fpr, im at 42psi, walbro highflow 250lph pump, exospeed stage two cam, head has new valves, guides, ported/polished, endyn rollerwave pistons, eagle rods, ported jrsc, 8lb flywheel, clutchmasters stage3 clutch. what else do you need to know? </TD></TR></TABLE>
Duh there is your problem. Just get that **** tuned and you won't have an issue at all.
Are you running stock ECU?
Old Apr 11, 2007 | 09:18 AM
SiRay13's Avatar
I was using all of that before and I had no problem.
Old Apr 11, 2007 | 09:19 AM
Bejita's Avatar
42 PSI!?!?!??!?! WTF???? Stock injectors??? Holy crap....You answered your own question....BTW a super charger CAN NOT push 42 PSI so I think you're full of ****.
SiRay13's Avatar
It's not even drivable right now to get it tuned. Stock ecu right now, I will be changing that and having it tuned but I didn't want to have to tow it anywhere.
Old Apr 11, 2007 | 09:20 AM
SiRay13's Avatar
Default Re: (Bejita)
42psi on the fuel.
Bejita's Avatar
BWWHAHAHA...........MY bad.
Old Apr 11, 2007 | 09:22 AM
Bejita's Avatar
Yeah...Whenever you do anything that major, you must get a tune...If you even change the cams.....TUNE IT! You're never gonna run right with that setup until you get a lot of work done.
Old Apr 11, 2007 | 09:29 AM
ludesrv's Avatar
Put a stock regulator on for now.
Shanasman12
Apr 9, 2014 08:45 PM
Slammed95civic
88
May 16, 2013 08:41 AM
ja20_eg
Engine Management and Tuning
10
Aug 18, 2012 06:33 PM
pokmijn
Oct 3, 2007 04:57 PM
Mik3
Feb 5, 2006 06:55 PM
