B20A5
Old Apr 10, 2007 | 03:50 PM
hgca's Avatar
Default B20A5
Ok, I know there is alot of info on the site... And I have spent a while searching, but I can't find a good answer to my question....
I own a 85 CRX and it has the EW block motor. I was going to do a B series swap, Using Hasports mounts and axels.... I am a member of another board, and when I mentioned my swap was going to be a B20A5 they let me in on something..... maybe?
Do the B16, B18 and the B20A5 all have the same mounting points, as far as motor mounts? Becasue If I can't mount this thing up using the hasport mounts, I need to look at something else.
Second, and in turn, if the mounts are totaly different,.....??? I all ready have the entire top end of the motor, could I use a different block? for exsample, use the B20 head on a B18 block?
I am sorry if I missed this info somewhere in the forum.... "and for the sake of all newbies" This is a HUGE forum..... it is about 10X's as big as the CRX forum I am on, and to search and then sift threw 60-80 posts takes A LONG *** TIME. I know seeing usless posts is annoying.... but so is spending 3 weeks researching something that could be answered in 10 seconds by your knowageable members.
P.s. this is my first post.... HI, my name is tom.
Thanks
Old Apr 10, 2007 | 04:07 PM
doood's Avatar
been there done that
Default Re: B20A5 (hgca)
those eariler b20a's share nothing in common with the rest of the b series engines. you cannot use that block with a vtec head for the common b20vtec. it also mounts differently than other b series. it's called the red headed bastard step child motor for a reason.
Old Apr 10, 2007 | 05:11 PM
hgca's Avatar
AHHHH, that's the same thing they called it.
Ok, so, I have just the top end out of a 1990 (I wasn't realisticly looking at Vtec)
can I use it on different block?...??? One of the typical B series motors?
It sounds alot like I have recently aquired a bunch of useless parts......
Old Apr 10, 2007 | 05:47 PM
GoldLudeRay's Avatar
you are going too find alot more info on the b20a5 on a prelude site
try http://www.preludepower.com
vist the 3rd gen section
to answer the ? mounts will be different on the b20a5. they have the gangsta lean unlike other b series motors. you can put a vtec head on the b20a5 but it is very,very,very defferent when compared too a normal vtec head swap. also i am perty sure the b20a5 motor will require you modify the hood. those motors are different they are best left in the 3rd gen. they are a better motor than most people think. vist preludepower.com to find out about why the b20a5 is different, you will probally find out the motor is a beast turboed.
Atmosfear
14
May 29, 2010 09:31 AM
turbob16ef
Oct 1, 2005 07:19 AM
EFHbSi
May 1, 2005 11:18 AM
91teg
Aug 22, 2004 08:15 AM
nis_SHlude
Mar 22, 2004 06:11 AM
