Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Ditch the torque mounts?
Old May 26, 2010 | 09:25 PM
Atmosfear's Avatar
Default Ditch the torque mounts?
I just installed a set of Innovative 95A mounts and would like your thoughts on whether it is safe to get rid of the torque mounts. I did a search and came up short in the RR/AX forum.
I tried searching the rest of the forum and all I could find was the typical cross-talking jibberish.
I dropped in my new ITR swap today but it is missing the rods that connect the torque mounts to the frame rails. Id rather not hunt for some if I really dont need them.
Old May 26, 2010 | 09:30 PM
civichb20's Avatar
PM Garage
Default Re: Ditch the torque mounts?
are you talking about the front mount? or both front and rear?
you should be fine with out the front a lot of people dont run them when they do a b series swap. try posting the question in the tech area where you think best.
Old May 26, 2010 | 09:31 PM
Atmosfear's Avatar
The two front ones that bolt both sides of the block to the lower frame rails.
Old May 26, 2010 | 09:38 PM
dirty19's Avatar
Ridin Dirty in Cali
Ditch em... i dont know anyone who still uses them after putting in any kind of aftermarket mounts.
Me included with my B-16
Old May 26, 2010 | 09:42 PM
Atmosfear's Avatar
Exactly what I wanted to hear. Thanks guys.
Old May 27, 2010 | 02:23 AM
Stinkycheezmonky's Avatar
Suspetise...
+1 for not using them with my HASport mounts.
Old May 27, 2010 | 11:38 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
What year car is this, I'd say use it. I'm using it in my DA with Innovative solid mounts and it def makes a difference on a high tq car........
I actually just bought a new one and filled it in to make it solid.
Old May 27, 2010 | 11:57 AM
Suspetise...
High torque car? What the heck are you driving, we're all driving Hondas!
Old May 27, 2010 | 02:03 PM
civichb20's Avatar
PM Garage
turbo charged RDX lol
Old May 27, 2010 | 02:09 PM
blackGSRcoupe94's Avatar
i have all my motor mounts filled with Sika window urethane event the two front torque mounts, solid *** a ****.
Old May 27, 2010 | 05:46 PM
Mattb16teg's Avatar
Community Builder
High tw for a Honda
x2 cheap easy mod!
Old May 28, 2010 | 11:02 AM
rick_rabies's Avatar
I'm not Rick!
i had a built gsr turbo motor in my 4dr eg. with cheapy aftermarket 95a motor mounts without torque mounts and it was fine, nice and stiff...
i think they are more for security of your motor mount brakes. (not the original purpose though)
Old May 28, 2010 | 11:15 AM
siblues's Avatar
95A Innovatives are pretty stiff I am running the softer set without the mounts in my car and I am making over 500 hp with no problems.
Old May 28, 2010 | 11:27 AM
Suspetise...
The front lower mounts are actually mostly for NVH control. With all stock mounts, they are designed to work as a system. With stiffer aftermarket mounts, things change. There's a reason HASport doesn't make those
Old May 29, 2010 | 09:31 AM
90blackcrx's Avatar
Awhile back Brian G from hasport chimed in on this question, he said to keep them just in case you ever get into an accident, safety reasons I guess. Take it for what its worth.
vinnyme50
13
Nov 30, 2023 05:38 PM
tyrel-gsrturbo
Aug 25, 2021 08:18 AM
B_Swapped93
Oct 28, 2013 06:22 AM
De_tour
Oct 6, 2006 09:48 PM
