Exhaust Manifold Studs?
A stout set of vice grips. It will be even easier if the motor is warm.
I replaced all of mine with studs from Honda not to long ago and that was the easiest way I found.
where can I find these online?
I've noticed on bernardiparts.com that they only sell the nuts for the manifold, and the studs come with the complete head
Anyone know other place where they don't charge 1700$ for 9 studs?just looking to replace studs, as I broke 2, and would like to replace all while at it.
thread one nut onto it. then put a lockwasher on it, followed by another nut.
hold the outer most with a wrench, and turn the innermost counterclockwise, and this will tighten up the lockwasher, and when you hold the outer bolt, it will make the stud come out.
i tried with vise grips, and it didn't work, they kept rounding off.
Last edited by rexman2002; Jul 8, 2009 at 03:35 PM. Reason: Edited to take out unnecessary comments.
First off, no need to get all hostile.
Second, do you need the studs that bolt the exhaust manifold to the head or the studs that hold the exhaust manifold to the collector pipe?
Third, have you tried any local junkayrds?
Try here: www.car-part.com
what? hostile, about what? what did you edit?
I just asked that guy where he got the oem studs from.
the 9 studs that go into the head.
I'd rather replace all with new studs, than old rusted ones.
I will.
checked rockauto, all they have is nuts. Anyone know the size of the head studs, maybe I can source some at auto zone, or pepboys?
^^^how did you get that?
what website is that, can you order those online?
thanks!!...
EDIT: I'm an idiot and can't navigate an online parts catalog worth ****.
thank you geneeunit for the diagram and the part number.
/thread
thanks!!...
/thread
http://estore.honda.com/
you can always just go into your local dealer and tell them what you need, not all parts counter workers are douches.
