Upper A Arm Question
Old Apr 10, 2007 | 12:22 PM
Disturb3dMind3d's Avatar
Default Upper A Arm Question
Will a upper a arm (front right/ passenger to be specific) from a 95 Honda Civic hatch fit on a 2000 Honda Civic Coupe? I'm thinking yes because its the same part as a camber kit and usually they sell one that works with 92-00 civics. Please validate my conclusion or correct me if I'm wrong.
Old Apr 10, 2007 | 12:30 PM
greengiant's Avatar
Default Re: Upper A Arm Question (Disturb3dMind3d)
no the upper a-arms aren't interchangeable. you need an upper a-arm from a 92-95 civic. the camber kit is the same because it mounts between the upper a-arm mounts and body.
if you look at the skunk2 front camber kits (upper a-arm with adjustable balljoint) the part numbers are different for 92-95 and 96-00 civics.
Old Apr 10, 2007 | 12:31 PM
4drgsr96's Avatar
i dont thing so, because the 92-95 a arms have actual studs on the arms to bolt up to the chassis whereas the 96-00 dont.
Old Apr 10, 2007 | 12:32 PM
Default Re: Upper A Arm Question (greengiant)
sweet thnx for the fast reply. saved me form wasting $60 on buying a part that won't fit.
Old Apr 10, 2007 | 12:39 PM
By any chance could any of u 2 pull up an assembly pic from majestics honda? I can't find it...
Old Apr 10, 2007 | 01:00 PM
EL Vap133's Avatar
Old Apr 10, 2007 | 01:07 PM
Default Re: Upper A Arm Question (EL Vap133)
thanks didn't even know what it was under in the options
Old Apr 10, 2007 | 02:15 PM
Luserkid's Avatar
You have to replace the bushings and I believe theyll fit. Most upper camber kits are 92-00 fitting.
Old Apr 10, 2007 | 03:00 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Disturb3dMind3d &raquo;</TD></TR><TR><TD CLASS="quote">thanks didn't even know what it was under in the options</TD></TR></TABLE>
It was under "knuckle".
mpls
Mar 17, 2009 06:39 PM
Tuner Eddy
Dec 6, 2007 08:50 PM
ncVTEC1313
Jun 26, 2004 04:49 PM
Kalokohan
Apr 10, 2003 08:44 AM
SRd240sx
Apr 10, 2003 01:55 AM
