91 EX No Spark
Old Apr 10, 2007 | 12:12 PM
Honda Tool's Avatar
2010 Honda-Tech Poker champion
Default 91 EX No Spark
I have a 91 EX coupe auto. Just quit running one day. Cranks fine, and is def getting fuel. It IS NOT getting any spark at all. I tried pulling codes, and check engine light just stayed on solid. It has a PT3-A72 ECU with out the LED view. I bought a matching # ECU off ebay, and it does have the LED on the ECU???? I tried starting it late last night, no spark and battery pooped out before i could try and get a code. Will see what i get later, but any other suggestions??
Old Apr 10, 2007 | 12:13 PM
Honda Tool's Avatar
Default Re: 91 EX No Spark (Honda Tool)
Forgot to mention it has brand new wires, plugs, cap, rotor. All replaced after it quit running.
Old Apr 10, 2007 | 03:52 PM
hondadude's Avatar
Are you getting power to the coil on the Black/yellow wire when cranking?
Have you checked for ignitor pulse when cranking?
Is the ground at the T-stat housing clean and tight?
Old Apr 10, 2007 | 07:36 PM
Honda Tool's Avatar
Default Re: 91 EX No Spark (hondadude)
The ground is good. I am charging the battery over night. Didnt have time today to mess with it. I can test black/yellow tomorrow. How do you check for ignitor pulse? Thanks
Old Apr 10, 2007 | 07:39 PM
hondamanwill's Avatar
Ignitor most likely, I bet my kid on it.
Old Apr 10, 2007 | 07:43 PM
Honda Tool's Avatar
Default Re: (hondamanwill)
What about the whole solid CEL when checking for codes? And what is up with 2 computers having same #'s 37820-PT3-A73 And one has LED window and one does not? I though solid CEL was bad ECU. I havent been able to check with new ECU yet.
Old Apr 11, 2007 | 06:16 PM
Honda Tool's Avatar
Default Re: (Honda Tool)
Ok it no longer has a solid CEL, but still no spark. Checked grounds again and they are def good. There is constant power to black/yellow wire at distributor. It fluctuates when cranking but stays above 10 V.
Help me get this piece running.
Old Apr 12, 2007 | 12:53 PM
Honda Tool's Avatar
Any other suggestions before I just replace whole distributor?
Old Apr 12, 2007 | 03:20 PM
hondadude's Avatar
Test light on ground side of coil; when cranking it should pulse.
If no pulse replace ignitor.
Old Apr 12, 2007 | 07:12 PM
Honda Tool's Avatar
Default Re: (hondadude)
I got it running. I took an ignitor from a junk f22a External coil motor, and borrowed a coil from a b18 distributor. Probably was igniter. thanks for the help hondadude. Hard to get replies if it is not about lambo doors, or JDM turn lights. lol
Mtrester92
Jan 4, 2016 05:31 PM
Wagovanagon
Aug 14, 2015 03:54 PM
troubleshootin
Mar 6, 2012 05:26 PM
Fo-Do Fanatic
Apr 18, 2010 11:32 PM
Rushen_Racer
Aug 17, 2004 07:42 PM
