should i change the base spring in my setup?
Old Apr 10, 2007 | 11:21 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default should i change the base spring in my setup?
most of you know the car from last year, leaving at 8200 on the 2 step with no antilag. this year i will have antilag and 13" wheels. my question is i have a .9 bar spring and with the gate hooked to the compressor housing, the lowest i have seen is 15-16 psi. is this ok to launch at with the t3t67ho on an 83mm gsr? or should i lower the base and have the option to increase launch boost? plan on running as much boost up top as the turbo will make. thanks in advance.
Old Apr 11, 2007 | 02:45 AM
DaveF's Avatar
Default Re: should i change the base spring in my setup? (boostedcivicsir)
put a 20 psi spring in it
Old Apr 11, 2007 | 03:34 AM
Mr. Badwrench
Default Re: should i change the base spring in my setup? (dturbocivic)
ill just cap it off.
smartass he hee.......
Old Apr 11, 2007 | 05:03 AM
nasteboyii's Avatar
ALL I CAN SAY IS
YES
this will be fine mikey, if i have to ill prove it to ya
when i get this motor back together
d
Old Apr 11, 2007 | 05:13 AM
Mr. Badwrench
Default Re: should i change the base spring in my setup? (nasteboyii)
waiting for joe to tell me to pour beer on it.
Old Apr 11, 2007 | 06:34 AM
Turbo-charged's Avatar
no you dont pour beer on it, you fill the wastegates with beer to increase pressure.
i just put smaller springs in my wastegates. im taking them out and putting the 15psi springs back in it.
Pumpking.
Nov 2, 2016 09:35 AM
turbo boost
May 6, 2008 04:35 PM
high_octane
Oct 12, 2007 02:58 AM
AaronJ
May 14, 2007 09:07 PM
Lucky_Smurf
Sep 22, 2004 06:31 AM
