GSR - Jackson Racing - AFC - AEM FS
Old Apr 10, 2007 | 11:20 AM
22seccivic's Avatar
Default GSR - Jackson Racing - AFC - AEM FS
GSR B18C1 - OBD1
Jackson Racing Supercharger
Rebuilt head with new valve guides.
AEM Adjustable cam gears
AEM fuel rail, adjustable pressure regulator, and fuel pressure gauge on rail.
New Timing belt and water pump, spark plugs and wires.
Missing crank pulley. ( I used it for another project ) I was going to get a B20 pulley as it adds a few PSI to the supercharger.
MSD cap w/ external coil and MSD rotor
MSD SCI ignition
New in box APEX AFC, DSM 450CC injectors w/ resistor block
I have a rising rate fuel pressure regulator (FMU) as well if you don’t want to run the setup on the line above.
$1900. I live in Indianapolis. I can help deliver depending on location.
Also, I have an inline fuel pump that is the correct size for this application although I can’t remember what size it is
I have an ECU but I am using it in a Del Sol that has an LS motor. I may be interested in swapping for an LS ecu.
I have a couple of engine mounts.
I have a 5th gear set for a ITR with a good set of bearings. ( I swapped an LS 5th gear into my tranny)
Old Apr 11, 2007 | 07:30 AM
22seccivic's Avatar
Default Re: GSR - Jackson Racing - AFC - AEM FS (22seccivic)
BUMP BUMP
Old Apr 26, 2007 | 05:49 PM
b18c inside's Avatar
still for sale? how much for the supercharger?
k20coupe
21
Jul 10, 2008 07:52 PM
justinb18c
Oct 25, 2005 02:27 PM
94SHOWLS
May 4, 2004 03:28 AM
wtc7676
Apr 27, 2004 05:51 PM
dwilson
Oct 17, 2002 09:03 PM
