Suspension & Brakes Theory, alignment, spring rates....
swaping brakes from DC to EG
Old Apr 10, 2007 | 08:59 AM
mymeatb18
Default swaping brakes from DC to EG
I have a 94 LS that i plan on selling so i want to take out the front and rear brakes and swap them for the ones that are in my 92 CX. In the end both cars need to be drivable, i plan on doing this within one day of about 6 hours.
I just wanted to know what i need to do to make this work, i know i need the rear trailing arms and front spindles with the whole brake assembly. what else do i need?
Do i need brake lines? Prop valve? e brake cable? Would the integra having ABS be a factor?
Old Apr 10, 2007 | 03:28 PM
mymeatb18
Default Re: swaping brakes from DC to EG (mymeatb18")
bump
Old Apr 11, 2007 | 12:41 AM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mymeatb18" &raquo;</TD></TR><TR><TD CLASS="quote">Do i need brake lines? Prop valve? e brake cable? Would the integra having ABS be a factor?</TD></TR></TABLE>
Brake lines, use according to which brakes it came off of (use Integra lines for Integra brakes, etc)
Prop valve, for the Civic
Yes, ABS will not be functional in the Integra
Old Apr 11, 2007 | 10:15 AM
mymeatb18
Default Re: swaping brakes from DC to EG (BlueIntegraBoy)
so i use the prop valve on the integra and put it into the civic and the lines from the prop valve to the brakes?
Old Apr 11, 2007 | 10:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mymeatb18" &raquo;</TD></TR><TR><TD CLASS="quote">so i use the prop valve on the integra and put it into the civic and the lines from the prop valve to the brakes?</TD></TR></TABLE>
No, the LS prop valve will not fit the EG. You need one from a 94-95 RS or 90-93 Integra. You need the rubber brake lines, not the metal ones.
Old Apr 11, 2007 | 01:20 PM
mymeatb18
an rs has rubber brake lines? and when putting the civic brakes on the integra i dont need to change lines or prop valve?
Old Apr 11, 2007 | 01:37 PM
I mean the rubber lines from the end of the metal brake line to the caliper.
Old Apr 12, 2007 | 11:08 AM
mymeatb18
thanks bro
beamer
Oct 24, 2018 11:35 PM
honvic21
Oct 1, 2008 04:46 PM
glazedham42
Feb 27, 2006 06:04 AM
truevietluv636
12
Feb 25, 2006 05:14 PM
