Need some info on brake swap for my 92 civic
i got a 92 civic hatchback vx and wanted to upgrade my brakes. dont have much cash so im looking into doing a full swap from a 94+ integra. front and rear. Could someone give me a full list of parts i might need from an integra w/o abs.
so far i got these things but need the year and model of the car its from.
master cylinder
propotional valve
calipers
brake lines
upper and lower control arms
master cylinder
propotional valve
calipers
brake lines
Re: Need some info on brake swap for my 92 civic (truevietluv636)
You can get the brakes from an Integra with ABS if you wanted.
Parts:
1. Front knuckle assembly including upper arm (for convenience) and brake lines
2. Rear trailing arm assembly with brake lines and ebrake cables
3. Civic 15/16" MC from 1991 Civic EX or 1994-1995 Integra RS
4. 40/40 Prop valve not necessary, but can be installed from a 1990-1993 Integra or 1994-1995 Integra RS
Parts:
Re: Need some info on brake swap for my 92 civic (BlueIntegraBoy)
thanks. for the front knuckle and rear trailing arms, are they the same for all 94+ integras. i dont want to install abs so if i buy integra brakes that are equiped with abs, are there any other mods necessary for install.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by truevietluv636 »</TD></TR><TR><TD CLASS="quote">thanks. for the front knuckle and rear trailing arms, are they the same for all 94+ integras. i dont want to install abs so if i buy integra brakes that are equiped with abs, are there any other mods necessary for install. </TD></TR></TABLE>
All the same. Doesn't matter if the car is ABS or not, it will bolt up to your car without any modifications.
i might buy the MC and the Prop Valve from someone online and was wondering if anyone knows if there is any part number on these so i would know its for a 94-95 integra rs.
Re: Need some info on brake swap for my 92 civic (BIGGINS LS-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIGGINS LS-VTEC »</TD></TR><TR><TD CLASS="quote">you dont use the integra there is a bolt up post on here about it you use the acura legend
Huh?
Huh?
So the 91 Civic 4-door EX brake MC is 15/16 and will bolt up directly to the stock EG brake booster with no mods?
Re: Need some info on brake swap for my 92 civic (MENACEteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MENACEteg »</TD></TR><TR><TD CLASS="quote">So the 91 Civic 4-door EX brake MC is 15/16 and will bolt up directly to the stock EG brake booster with no mods?</TD></TR></TABLE>
Yes.
Yes.
