Swapping gauge clusters - '94 GSR to '98+ Type R
Will i need to do any modifications as far as wiring or harnesses are concerned? I've got it sitting in my room waiting to go in, just not sure if it'll work.
Also, if i put a Non SRS wheel in my '94 with an OBD2 ('96+) cluster, is there a way to turn the SRS light off? I noticed there was no bulb on the back of the cluster to do this, so i'm assuming there must be another way...
Thanks in advance.
Thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dorifto_83 »</TD></TR><TR><TD CLASS="quote">there is a yellow plug you have to pull out</TD></TR></TABLE>
For the airbag or cluster? The Haynes manual says there is a little black thing you plug the airbag harness into when it isn't plugged in to the steering wheel...
9.3.S.I.L.U.D.E.
18
Aug 20, 2009 01:50 AM
_Cyclone_
Jul 16, 2005 03:37 PM
