help just lowered on sk2 springs
Old Apr 9, 2007 | 08:33 PM
94hondacivicvtec's Avatar
Default help just lowered on sk2 springs
i just dropped my car 2.25 in front and 2.5 in back. it feels like im hitting the uca on the engine bay. how do i stop it from doin that if it is?
Old Apr 9, 2007 | 09:06 PM
Default Re: help just lowered on sk2 springs (94hondacivicvtec)
im also running stock shocks if that helps-
Old Apr 9, 2007 | 09:19 PM
Chim Chim's Avatar
Get better dampers and/or raise your car up until it stops hitting... There's no other alternative...
Old Apr 9, 2007 | 09:21 PM
allstockb18c's Avatar
did you cut the bumpstop if so how much did you cut off, if you cut too much your uca is prob hitting against the fender well
Old Apr 9, 2007 | 09:24 PM
Default Re: help just lowered on sk2 springs (Chim Chim)
this might sound noob but dampers? do you mean shocks
Old Apr 9, 2007 | 09:26 PM
i didn't cut the bump stops at all, do you think thats the kinda loud bang i hear when i come out of drive ways?
Old Apr 9, 2007 | 09:27 PM
onesikdb8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hondacivicvtec &raquo;</TD></TR><TR><TD CLASS="quote">im also running stock shocks if that helps- </TD></TR></TABLE>
No it doesn't.....you should always replace your shocks when replacing it with lowering springs.
Old Apr 9, 2007 | 09:32 PM
Default Re: help just lowered on sk2 springs (onesikdb8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onesikdb8 &raquo;</TD></TR><TR><TD CLASS="quote">No it doesn't.....you should always replace your shocks when replacing it with lowering springs.</TD></TR></TABLE>
no ****, i was just sayin if it helps you guys answer my question. i plan on getting new shocks in a week or two.
Old Apr 9, 2007 | 09:33 PM
if your on stock stocks then you should have cut part of the bumpstop to allow the suspension to a travel a lil bit. Since you lowered the car 2.5 inches you prob only have less then a inch of travel before you bottom out.
Old Apr 9, 2007 | 09:34 PM
instrument's Avatar
lowering you car that much on stock shocks is somewhat retarded.
its probably not hitting, it just feels awful because its lowered on STOCK SHOCKS
when i lowered my crx i contacted the inner fender, i had to bang it out with a sledge hammer.
Old Apr 9, 2007 | 09:35 PM
Default Re: help just lowered on sk2 springs (allstockb18c)
so i guess i should cut them then, how mutch should i cut off- (i will be getting new shocks in a week or two. i was thinking some kyb's
Old Apr 9, 2007 | 09:37 PM
on stock shocks i usually cut half of it off, leave the top half in the car. But with performance shocks you may not want to cut the bumpstops due to the short compression of the shock.
Old Apr 9, 2007 | 09:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">lowering you car that much on stock shocks is somewhat retarded.
when i lowered my crx i contacted the inner fender, i had to bang it out with a sledge hammer.</TD></TR></TABLE> i bet it is but i didn't plan on leaving it that way. figure fuckk it, it will be fine for now.
Old Apr 9, 2007 | 09:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allstockb18c &raquo;</TD></TR><TR><TD CLASS="quote">on stock shocks i usually cut half of it off, leave the top half in the car. But with performance shocks you may not want to cut the bumpstops due to the short compression of the shock.</TD></TR></TABLE> so what should i do for now?
Old Apr 9, 2007 | 09:40 PM
well you can deal with riding on your bumpstops until you buy new shocks but if you cant stand it then go ahead and cut the bumpstops for now.
Old Apr 9, 2007 | 09:45 PM
fuckk i can deal with it but do you think it will fuckk any thing up? thats the real question . and if i cut them how hard is it to put in new ones?
Modified by 94hondacivicvtec at 11:03 PM 4/9/2007
Old Apr 9, 2007 | 09:46 PM
Chim Chim's Avatar
If your UCA is hitting the shock tower, you might want to raise it up enough to keep it from hitting... Cutting bump stops won't alleviate that portion of your problems...
Old Apr 9, 2007 | 09:47 PM
nope, you will know when the uca are hitting, all you gotta check is your strut towers for some nice dents.
Old Apr 9, 2007 | 09:48 PM
how would i rase it? there lowering springs
Old Apr 9, 2007 | 09:49 PM
If you are on stock shocks you will hit the bumpstop first before the uca will even rub against the strut towers.
Old Apr 9, 2007 | 09:51 PM
so i won't fuckk any thing up right? (just to clarify)
Old Apr 9, 2007 | 10:02 PM
you will be fine
Old Apr 9, 2007 | 10:05 PM
right on, thanks for the help
amej8
Suspension & Brakes
13
Sep 15, 2008 09:45 PM
xXSilentScreamXx
11
Sep 9, 2007 09:52 PM
cheeta
Honda S2000
Apr 29, 2006 08:40 AM
mattdenali
Suspension & Brakes
Aug 21, 2005 12:29 AM
Smeeg Heed
Dec 13, 2003 03:51 PM
