help just lowered on sk2 springs
i just dropped my car 2.25 in front and 2.5 in back. it feels like im hitting the uca on the engine bay. how do i stop it from doin that if it is?
Re: help just lowered on sk2 springs (94hondacivicvtec)
did you cut the bumpstop if so how much did you cut off, if you cut too much your uca is prob hitting against the fender well
i didn't cut the bump stops at all, do you think thats the kinda loud bang i hear when i come out of drive ways?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hondacivicvtec »</TD></TR><TR><TD CLASS="quote">im also running stock shocks if that helps- </TD></TR></TABLE>
No it doesn't.....you should always replace your shocks when replacing it with lowering springs.
Re: help just lowered on sk2 springs (onesikdb8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onesikdb8 »</TD></TR><TR><TD CLASS="quote">No it doesn't.....you should always replace your shocks when replacing it with lowering springs.</TD></TR></TABLE>
no ****, i was just sayin if it helps you guys answer my question. i plan on getting new shocks in a week or two.
if your on stock stocks then you should have cut part of the bumpstop to allow the suspension to a travel a lil bit. Since you lowered the car 2.5 inches you prob only have less then a inch of travel before you bottom out.
lowering you car that much on stock shocks is somewhat retarded.
its probably not hitting, it just feels awful because its lowered on STOCK SHOCKS
when i lowered my crx i contacted the inner fender, i had to bang it out with a sledge hammer.
Re: help just lowered on sk2 springs (allstockb18c)
so i guess i should cut them then, how mutch should i cut off- (i will be getting new shocks in a week or two. i was thinking some kyb's
on stock shocks i usually cut half of it off, leave the top half in the car. But with performance shocks you may not want to cut the bumpstops due to the short compression of the shock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">lowering you car that much on stock shocks is somewhat retarded.
when i lowered my crx i contacted the inner fender, i had to bang it out with a sledge hammer.</TD></TR></TABLE> i bet it is but i didn't plan on leaving it that way. figure fuckk it, it will be fine for now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allstockb18c »</TD></TR><TR><TD CLASS="quote">on stock shocks i usually cut half of it off, leave the top half in the car. But with performance shocks you may not want to cut the bumpstops due to the short compression of the shock.</TD></TR></TABLE> so what should i do for now?
well you can deal with riding on your bumpstops until you buy new shocks but if you cant stand it then go ahead and cut the bumpstops for now.
fuckk i can deal with it but do you think it will fuckk any thing up? thats the real question . and if i cut them how hard is it to put in new ones?
Modified by 94hondacivicvtec at 11:03 PM 4/9/2007
If your UCA is hitting the shock tower, you might want to raise it up enough to keep it from hitting... Cutting bump stops won't alleviate that portion of your problems...
