Timming belt keeps slipping off center a little. . .
Old Apr 9, 2007 | 07:29 PM
tireiron's Avatar
Default Timming belt keeps slipping off center a little. . .
I recently finished my LS/VTEC and my timming belt keeps slipping off the cams and settles over the tensioner/cam sprockets/and crank sprocket about 4mm. It has worn a very small line onto the belt a little. Just wondering what would cause this to happen? What would make the belt come/slide over a bit?
Modified by tireiron at 5:04 AM 4/10/2007
Old Apr 10, 2007 | 05:22 AM
Padawan's Avatar
Darth ModerVader
Default Re: Timming belt keeps slipping off center a little. . . (tireiron)
Perhaps a bad tensioner? Are you using a new one?
Old Apr 10, 2007 | 08:31 AM
bboyfreeze's Avatar
do you have that special washer that goes in between the crank sprocket and pulley? i had the same problem...washer was on the wrong side.
Old Apr 10, 2007 | 12:24 PM
tireiron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Perhaps a bad tensioner? Are you using a new one?</TD></TR></TABLE>
Using the same one. I have two others around the garage I can use. One off a b16a and the other off a B18b from an old engine tear down. Are the tensioners all the same for b-series motors?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboyfreeze &raquo;</TD></TR><TR><TD CLASS="quote">do you have that special washer that goes in between the crank sprocket and pulley? i had the same problem...washer was on the wrong side. </TD></TR></TABLE>
Good idea! I will double check that again tonight.
Old Apr 10, 2007 | 01:21 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tireiron &raquo;</TD></TR><TR><TD CLASS="quote">Are the tensioners all the same for b-series motors? </TD></TR></TABLE>
Yes, they're the same, but I'd suggest picking up a brand-new one.
Old Apr 10, 2007 | 07:12 PM
tireiron's Avatar
Found the prblem and fixed it. Had the washer on incorrectly. Thanks bboy.
nes1871
Oct 13, 2013 02:24 AM
slayerP
Apr 8, 2006 05:21 PM
DocSean
Jan 16, 2006 09:20 PM
dwn4cause
Jun 20, 2005 09:10 AM
Poop111444
Jul 16, 2003 09:39 AM
