Can I modify my Rims to Get a Certain Offset?
Old Apr 9, 2007 | 06:38 PM
RickyJa's Avatar
Default Can I modify my Rims to Get a Certain Offset?
Hey y'all, I hope someone may help me with the situation.
I recently bought some ADR Mach 8 rims for my 97 SH which is lowered. The person that I bought them from took them off his 99 Base Lude, also lowered. After I put the rims on I realized that the rear wheels were touching when making sharp corners and when exessive load hits the back.
The wheel specs are as follows;
17x7 40mm
I have 17/205/40ZR tires on.
Has anyone ever taken their rims to a machine shop to modify the rims because of the wrong offset?
I was just curious to see if a machinist can take off a few fraction of an inch to make them fit my Lude.
If that cannot work I may just have to try and sell or swap them.
Old Apr 9, 2007 | 07:00 PM
r.wright's Avatar
Default Re: Can I modify my Rims to Get a Certain Offset? (RickyJa)
i have been told it can be done but only like 3 mm or so..
i am assuming u are rubbing the outer fender, correct?
Old Apr 9, 2007 | 07:09 PM
jarel's Avatar
have you thought about rolling/cutting your fenders?
Old Apr 9, 2007 | 09:01 PM
Conflicted's Avatar
Default Re: (jarel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jarel &raquo;</TD></TR><TR><TD CLASS="quote">have you thought about rolling/cutting your fenders? </TD></TR></TABLE>
For some reason, especially with Mazda6's, this is a huge thing. People who get larger wheels usually have to get their fenders rolled even if they arent lowered. I have been considering it with my speed6 but dont know if I am going to modify it.
Old Apr 10, 2007 | 06:46 AM
RickyJa's Avatar
Default Re: Can I modify my Rims to Get a Certain Offset? (Mr. R*L*X)
Yep, rubbing the fenders. Would I need to take the car to a shop to roll the fenders or can I do it myself?
Old Apr 10, 2007 | 08:10 AM
Conflicted's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RickyJa &raquo;</TD></TR><TR><TD CLASS="quote">Yep, rubbing the fenders. Would I need to take the car to a shop to roll the fenders or can I do it myself?</TD></TR></TABLE>
You can actually buy a fender roller or rent one from someone. You basically have to remove the wheel below the fender you are going to roll and the roller attaches to where your lugs would go, so it gives you an even roll. You usually want to utilize a heat gun too so you can heat up the paint a bit to reduce any chance of cracking in the paint. You basically do this 4 times over, once for each fender and you're good.
Old Apr 10, 2007 | 08:58 AM
professorman's Avatar
Default Re: Can I modify my Rims to Get a Certain Offset? (Mani Fresh)
good stuff. Anyone here ever done it before? Is it easy/hard? Whats the difficulty level on this?
Old Apr 10, 2007 | 09:31 AM
FalkenSiR's Avatar
yea you can have the wheel milled a few mm's to increase your offset.
Old Apr 10, 2007 | 10:08 AM
Conflicted's Avatar
Default Re: Can I modify my Rims to Get a Certain Offset? (profroopchan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by profroopchan &raquo;</TD></TR><TR><TD CLASS="quote">good stuff. Anyone here ever done it before? Is it easy/hard? Whats the difficulty level on this?</TD></TR></TABLE>
Its very easy to do. I have done it on a friends car when he first got it. Not hard at all, the way we did it was to run the heat gun about 8 inches away so not to singe the paint but to make it a little malleable. Then you give it one or two good rolls or until you're satisfied that its rolled in as far as you'd like.
Its very simple, the most labor is taking off the wheel and setting up the roller four times.
Old Apr 10, 2007 | 11:25 AM
RickyJa's Avatar
Thanks for the comments. I will definitely look into rolling the fender.
Old Apr 12, 2007 | 07:42 AM
JDM SPEK's Avatar
yup. they pretty much got it. roll that fender in. ur wheels will be nice and sungged nicely.
Old Apr 22, 2007 | 06:46 AM
Conflicted's Avatar
Default Re: (JDM SPEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM SPEK &raquo;</TD></TR><TR><TD CLASS="quote">yup. they pretty much got it. roll that fender in. ur wheels will be nice and sungged nicely.</TD></TR></TABLE>
That should take you to a site where you can rent a fender roller. I would probably suggest finding people local to you who want to have a fender rolling meet or something like that to offset the cost of renting it. Good Luck.
Old Apr 22, 2007 | 06:47 AM
Conflicted's Avatar
http://www.esetuning.com/category-s/223.htm
Shinny
Jun 18, 2011 09:53 PM
strtracedrmr
Honda Civic (2001 - 2005)
Sep 9, 2007 05:33 PM
RickyJa
Apr 10, 2007 08:29 PM
bananacruzier
Mar 14, 2002 10:27 AM
