piston/valve clearance with rs machines pistons in b20vtec
Old Apr 9, 2007 | 02:42 PM
b20powereDA's Avatar
Default piston/valve clearance with rs machines pistons in b20vtec
im wanting to know if it will be safe to run rs machines oem itr replica pistons in a b20 vtec with gsr cams on a b16 head. also, im pretty sure the piston/valve clearance would be ok with this setup but i was also wondering how much i could mill the head without bumping the compression to high or having to deal with clearance issues. thanks in advance
Old Apr 9, 2007 | 07:27 PM
Default Re: piston/valve clearance with rs machines pistons in b20vtec (b20powereDA)
bump
Old Apr 9, 2007 | 07:35 PM
Runnerdown's Avatar
maybe you should ask rs machines?
but if its setup as stock with gsr cams there should be no clearance problems.
Old Apr 9, 2007 | 07:41 PM
RMF Headers's Avatar
B A N N E D
Default Re: piston/valve clearance with rs machines pistons in b20vtec (Runnerdown)
The RS pistons were made just for that combo.They have the bigger reliefs to clear the valves with just about any cams you want.Your cam timing would have to be way off in order for the valves to hit the pistons .Infact the valves will probably hit each other first before hitting the pistons.
Old Apr 9, 2007 | 07:46 PM
Default Re: piston/valve clearance with rs machines pistons in b20vtec (Sol Rosenberg)
u dont happen to have any ideo how much i could mill the head do u ?
Old Apr 9, 2007 | 08:07 PM
Natural Aspirations's Avatar
Why would you need to mill the head? compression is pretty high with that set-up already.
Old Apr 10, 2007 | 02:03 PM
Default Re: (Natural Aspirations)
heads a little messed up and needs to be resurfaced
Old Apr 10, 2007 | 02:47 PM
doood's Avatar
been there done that
Default Re: (b20powereDA)
then just have it milled enough to get straight again
Old Jun 21, 2007 | 12:53 PM
b20beast978's Avatar
Default Re: (doood)
thats what i would do
Old Jun 21, 2007 | 04:40 PM
soulpwr's Avatar
Default Re: (b20beast978)
how much you can mill depends on the rest of your setup. If you'll have adequate clearance between the p2h and the p2v after milling then you'll be fine.
Gunmetal_B20_Hatch
Dec 30, 2010 11:20 AM
gs1gsr
Jan 13, 2008 09:20 AM
gs1gsr
Jan 9, 2008 09:30 PM
HighRevn
Jul 18, 2007 06:03 PM
7mile
Feb 6, 2006 09:08 PM
