problems with axles on crx
Old Apr 9, 2007 | 02:02 PM
christion's Avatar
Default problems with axles on crx
Does somebody there know which honda type model uses longer axles??
I have a honda crx with a b18c1 turbo engine in my car, but it seems that the
driver side axle is a little bit short. When I turn the steering wheel to the right side completely and hit the gas, the axles pups out of the half shaft and breaks all the bearings and leave the intermediate shaft all chewed up. I don't use single traction anymore. My differential is welded together, so constanltly double traction!! I just want to know if I can't find a longer axle, because I am going to buy some racing axles and I don't want to ruin them. Let me know if somebody knows anything!!
Thanks allot!!
Old Apr 9, 2007 | 03:45 PM
SIred91's Avatar
Rainman
Default Re: problems with axles on crx (christion)
OH ****!!
Old Apr 9, 2007 | 04:06 PM
ALLMOTOR CRX's Avatar
what motor mounts are you using.. it doesnt sound like an length axle problem it might be the way your motor is sat down on the motor mounts... what mounts are they? i have a gsr as well in my crx with hasport mounts never had this type of problem with my car befor.. i might check the motor mounts.. i where you...
mafia
May 7, 2012 12:06 PM
gettinmoneyny
Jul 2, 2010 08:30 PM
djnikko
Apr 22, 2010 12:17 PM
kappa12
13
Apr 14, 2004 07:36 PM
DEVIN22CBR
22
Dec 13, 2003 08:42 PM
