break booster problem
Old Apr 9, 2007 | 01:37 PM
sasinorm01's Avatar
Default break booster problem
89 4dr ef non abs.........i just changed the MC , pads and rotors....because the pedal was going to the floor ...but after all that it is still going to the floor....is it the break booster not holding or what ?
Old Apr 9, 2007 | 02:24 PM
black88si's Avatar
Default Re: break booster problem (sasinorm01)
probably just some air in the lines. Try bleeding again. The brake booster is probably fine.
Old Apr 11, 2007 | 07:54 AM
sasinorm01's Avatar
Default Re: break booster problem (black88si)
well like an idot i forgot to bleed the bake brakes.... then while trying to bleed them i broke the bleeder valve...so now its time for rear disk converstion!!
Old Apr 11, 2007 | 07:56 AM
SIred91's Avatar
Rainman
That suckz man. The peddle problem can also come from the vacuum line at the booster being cracked or otherwise unhealthy.
Just something else to watch out for.
Greyknight1138
Suspension & Brakes
Apr 7, 2014 07:32 AM
namax
Jul 16, 2007 05:43 PM
HBK_DAVIDDD
17
Jan 19, 2007 06:37 AM
Del_Sol_s
27
Mar 4, 2006 06:49 AM
LAKER HATER
Oct 22, 2005 01:33 PM
