Swap smog?
Old Apr 9, 2007 | 01:35 PM
actionfigure's Avatar
Default Swap smog?
I plan on swapping my engine D15b7 for a Vtec D15b from Jap.
Will there be any problems passing the smog check?
Also, does anyone for see any other problems that I should know about.
This is greatly appreciated.
Thank you.
Old Apr 9, 2007 | 03:34 PM
jay_cue's Avatar
Default Re: Swap smog? (actionfigure)
no. its been done many times. just make sure that all smog items are connected.
Old Apr 9, 2007 | 05:50 PM
Default Re: Swap smog? (jay_cue)
Thank you.
I was worried about that since a friend told me that it may be a problem.
Old Apr 11, 2007 | 08:10 PM
lek9l's Avatar
As long as the engine has the same liters and series then you should be fine.
Old Apr 11, 2007 | 08:25 PM
jay_cue's Avatar
Default Re: Swap smog? (lek9l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lek9l &raquo;</TD></TR><TR><TD CLASS="quote">As long as the engine has the same liters and series then you should be fine.</TD></TR></TABLE>
Wow. What horrible misinformation.
How do you figure you can certify an integra motor in a civic if the motors have to have the same liters and series?
AutoXsi2000
Mar 13, 2016 02:11 PM
EF9*Hottie
Jan 11, 2008 12:58 PM
civicexowner
10
Nov 12, 2007 07:39 PM
THC07
Oct 7, 2005 07:24 PM
TypeRInNeed
Jan 6, 2002 10:07 PM
