help car sputtering at low rpm's
Old Apr 9, 2007 | 11:30 AM
ejallday's Avatar
Default help car sputtering at low rpm's
My rpm's have gone up to 1500-2000. I've read about cleaning the iacv but what will stop my car from sputtering. The only mods i have are cold air intake and header. Those are on a d16y7. All info will be greatly appreciated. Thanks yall.
Old Apr 9, 2007 | 12:48 PM
Perfectionist's Avatar
Default Re: help car sputtering at low rpm's (ejallday)
What's the problem? High idle, or sputtering?
Old Apr 10, 2007 | 11:29 AM
ejallday's Avatar
Default Re: help car sputtering at low rpm's (Perfectionist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote">What's the problem? High idle, or sputtering?</TD></TR></TABLE>
Sputtering.
When the car is cold or warm it sputters bad at a low rpm. If i mash it it stops or jerks like crazy.
Old Apr 10, 2007 | 01:38 PM
Shay91Racer's Avatar
yeah i need them to answer this question for me too....
Old Apr 10, 2007 | 03:49 PM
1fast4g63's Avatar
Default Re: help car sputtering at low rpm's (Shay91Racer)
The sputtering when smashing the gas pedal sounds like an ignition miss and during 96-97 honda civics had an emissions recall. Spark plug wires were known to cause engine hesitation and sputtering. Also in 98-00 civics had a problem during cold start ups, the engine would sputter due to a contaminated MAP sensor and some defective intake manifolds. Hope this helps
Old Apr 10, 2007 | 07:35 PM
ejallday's Avatar
Default Re: help car sputtering at low rpm's (1fast4g63)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fast4g63 &raquo;</TD></TR><TR><TD CLASS="quote">The sputtering when smashing the gas pedal sounds like an ignition miss and during 96-97 honda civics had an emissions recall. Spark plug wires were known to cause engine hesitation and sputtering. Also in 98-00 civics had a problem during cold start ups, the engine would sputter due to a contaminated MAP sensor and some defective intake manifolds. Hope this helps</TD></TR></TABLE>
Thanks yo. i'll check the wires tomorrow.
Old Apr 12, 2007 | 08:35 AM
does the same thing apply to 90-93 Accords?
Old Apr 21, 2007 | 06:58 PM
1fast4g63's Avatar
no, the recall does not apply to 90-93 accords. However a faulty ignition system cause the same problems in the year range you specified
Old Apr 21, 2007 | 08:20 PM
ejallday's Avatar
found it yo. it was the spark plugs. thanks for all of the info.
1sikhatch
Nov 30, 2006 09:55 AM
beatthisspeed69
Apr 3, 2006 05:50 PM
eL
11
Jan 19, 2005 01:13 AM
whatsgood
Sep 17, 2004 05:00 PM
crx00
Mar 13, 2004 06:39 AM
