OBDII car OBDI motor???
Old Apr 9, 2007 | 09:10 AM
hatchy69's Avatar
Default OBDII car OBDI motor???
i have a 96 hatch but i want to throw in a b16 sir-II motor which is obd-I....How can i make this happen so i have no problems. thanks
Old Apr 9, 2007 | 09:12 AM
YoungKadafi's Avatar
obd1 ecu, and obd2a to obd1 conversion harness, then your perfectly golden
Old Apr 9, 2007 | 09:21 AM
GG99's Avatar
Default Re: OBDII car OBDI motor??? (hatchy69)
http://www.boomslang.us/obd2to1.htm
Old Apr 9, 2007 | 09:30 AM
Pr0ject93hb's Avatar
Default Re: (YoungKadafi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi &raquo;</TD></TR><TR><TD CLASS="quote">obd1 ecu, and obd2a to obd1 conversion harness, then your perfectly golden</TD></TR></TABLE>
exactly.
Old Apr 9, 2007 | 10:01 AM
hatchy69's Avatar
Default Re: (Pr0ject93hb)
thanks , that thing is gonna very important when swap time comes
Old Jul 11, 2007 | 03:07 PM
d16lxciv's Avatar
I know this thread is a little bit old, but would you still be able to pass inspection with an obdI ecu? B/c doesn't the division of motor vehicles have to hook a scan tool up to the ecu for a readiness code, ecspecially if it is an OBDII vehicle? Doing the same swap so i am pretty curious as well, thanks!
Old Jul 11, 2007 | 05:20 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: (d16lxciv)
I have one in my 98 Coupe and I have to say, for a B16 it rips
Old Jul 11, 2007 | 06:17 PM
EK FLY's Avatar
Default Re: (5_Lug_B)
u need 99-00 si rear t bracket
convert the car to obd1
u need a obd2 alternator
96-01 integra or 99-00 si dizzy
and ur set use ur stock harness
Old Jul 11, 2007 | 06:59 PM
UGLYEK's Avatar
okay so i have this engine in my 97 hatch and i dont know what to do with the wire harness...is teh obd1 ecu and the obd2 to obd1 conversion harness all i need?..
Old Jul 11, 2007 | 07:43 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: (UGLYEK)
Yes, but if you want VTEC you have to wire it up or use an EX harness.
Old Jul 11, 2007 | 07:45 PM
UGLYEK's Avatar
okay well i want vtec....so how do i wire that up?.....Sorry new to all of this...
Old Jul 16, 2007 | 03:04 PM
d16lxciv's Avatar
would that still pass emissions?? i would love to throw a b16a in my ej6 4dr!
tianporn
Aug 9, 2011 04:58 AM
Muuugen
Jan 27, 2009 01:37 PM
big-cat
26
Oct 19, 2006 11:14 AM
B18 CYA
Apr 28, 2004 09:58 AM
allmtr
Jun 9, 2002 04:39 PM
